Can You Help Me Solve This Non-Elementary Differential Equation?
  • Thread starter Thread starter bishy
    Parameters
bishy
2y\prime\prime +2y\prime + y = 4 \sqrt{x}
charecteristic equation: x^2+x+\frac{1}{2}
roots: \frac{1}{2}\pm\frac{1}{2}i
homogenous solution: a \sin{\frac{1}{2}x} + b \cos{\frac{1}{2}x}
Wronskian: \left(\begin{array}{cc}\sin{\frac{1}{2}x}&\cos{\frac{1}{2}x}\\\frac{1}{2}\cos{\frac{1}{2}x}&-\frac{1}{2}\sin{\frac{1}{2}x}\end{array}\right) = -\frac{1}{2}
It would be nice to know if up to here, everyone else gets the same answer. After this I get into non elementary functions which is no where near the level of difficulty included within the course I'm taking. I haven't attempted to solve what comes next, frankly because I have no clue where to even begin. I think I probably made a mistake above, if someone can point me in the right direction that would be awesome. The method used is variation of parameters.
y_{1}=\sin{\frac{1}{2}x}
y_{2}=\cos{\frac{1}{2}x}
u_{1} = \int{4\sqrt{x}\cos{\frac{1}{2}x}dx}
u_{2} = \int{-4\sqrt{x}\sin{\frac{1}{2}x}dx}
ick
With x^2+x+\frac{1}{2} as your characteristic equation, I think your roots should be -\frac{1}{2}\pm\frac{1}{2}i. And then with the complex roots, the homogeneous solution should be in the form of
y=c_1e^{\lambda t}\cos(\mu t)+c_2e^{\lambda t}\sin(\mu t)
where the roots come from the form of \lambda \pm i\mu. Your form was missing the exponential term. Hope that helps a bit.
Yeah, jeffreydk is right. Your roots are incorrect and you neglected the exponential.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
