Calc III: Use of variables in functions
In the discussion about using variables in functions, participants clarify that while variables like x, y, and z can represent specific values in equations, they are not merely dummy variables. The context of a problem dictates the meaning of these variables, and swapping them does not change the underlying relationship represented by the equations. For example, in a fencing problem, the choice of which variable represents which dimension does not affect the final solution, as the equations yield the same results regardless of the assignment. Understanding the purpose behind variable selection is crucial for accurate interpretation in mathematical contexts. Ultimately, the significance of variables lies in their defined roles within specific applications.
PhysicsHelp12
I'm confused about whether or not I'm thinking about this correctly:
If I'm given an equation eg. 3x^2-2xy=3z+1 (just a random eg.)
Is it a correct assumption to think of the x,y and z in the equation as corresponding
to x,y and z as I'd think of them on the cartesian plane...They're not just dummy variables
but in this case actually represent something ...like they arent going to switch them around
on me and use y in place of z and x in place of y...
because x=sqrt(y) (right side of parabola) isn't the same as y=sqrt(x) ...so is this
assumption that x and y and z are used on purpose --and arent just 'dummy variables'
Mathematics news on Phys.org
I'm not sure I understand your question. In a specific application you are either told what "x, y, z" mean or you assign them yourself (and it would be a good idea to say what "x, y, z" mean at the beginning). If, in a problem, one person derives y= x2 and another x= y2, they really have the same thing- one graph has just swapped the x,y coordinates of the other. No, they are not just "dummy variables"- but swapping them around would just give the same graph in a different coordinate system.
If, for example, I have a problem that says "A farmer has 400 yards of fencing. He wants to fence a rectangular pasture in which he can use a river bank as one side (and so needs no fencing). What are the dimensions that will give the largest area?"
It is my choice whether I use x to mean the length of the side along the river bankand y the side perpendicular to it or vice-versa. If I do choose x to be the length of the side along the river bank, my equations become, "length of fencing used: x+ 2y= 400, area= xy" and I get x= 200 yards, y= 100 yards. If I choose it the other way around, y is the length of the side along the river bank, the equations become y+ 2x= 400, area= xy and I get y= 200 yards, x= 100 yards, but those are exactly the same answer.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
