Modify computer inverter to accept power from house inverter
The discussion centers on the issue of a computer restarting during power outages despite being connected to a whole-house UPS. The current setup involves a computer UPS that fails to recognize the power from the house UPS, leading to reduced backup time. Experts suggest that the house UPS may be a stand-by type, causing a delay in switching to inverter power, which can crash the computer. It is also indicated that the house UPS might output a crude sine wave, confusing the computer UPS. A potential solution discussed is to use a dedicated inverter for the computer that runs continuously, although it may not provide adequate warnings when backup power is low.
gotchanisa
I have a UPS at home - for the whole house. However, everytime there is a power outage, my computer restarts. It does not restart when the power comes back! I had an old computer UPS that I had that I connected to the computer. Now when the power goes, the computer does not restart - but the computer UPS does not 'recognize' the power coming from the main House UPS. So instead of a 5 hr back up - that the house UPS gives me, I only have the 15 min back up that the computer UPS can give me. I have talked to UPS manufacturers who say they need to fit a 'filter' which will solve the problem - but they were not able to make it. They said something about a pure sine wave output- not sure if I understood. Anyone have a cost effective solution that will make my computer inverter 'recognize' the power coming from my main inverter?
It sounds like the house UPS is of the stand by type rather than a double conversion type. In the event of a power outage a stand by type switches on its inverter and switches the load from the mains to the inverter. This isn't seamless so the computer crashes. If it was a double conversion type the inverter would be running constantly so change over would be seamless but there would be constant power loss in the inverter making it more expensive to run.
It also sounds like the house inverter only generates a crude approximation to a sine wave and that is confusing the computer UPS into thinking the input is too noisy to use. The vendor is saying that an inverter that generates a pure sine wave might not confuse the computer UPS.
I'm not sure what to recommend. A pure sine wave UPS capable of powering the whole house might be too expensive.
One possibility might be to buy an inverter rated for just the computer and connect it to the big battery in the house UPS. This inverter would run all the time so no issue when the power goes out. The only problem I see is that you might/wont get any warning when the 5 hours are up. You would have to rely on any warning the house UPS gives you.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
