How Do You Solve the Quantum Physics Integral Using the Residue Theorem?
Felicity
integral from - infinity to + infinity of
N/(k2+a2) * eikx dk
this is for a quantum physics problem (chapter 2 problem 1, gasiorowicz) where I am given A(k) = N/(k2+a2) and must calculate psi(x)
I am using the equation
psi(x,t) = integral from - infinity to + infinity A(k) ei(kx-wt) dk
which when t=0 goes to
psi(x,t) = integral from - infinity to + infinity A(k) eikx dk
I've tried integrating by parts, substitution and on my TI-89 however I am a little rusty with all these methods
Any help would be greatly appreciated
You need to do these sort of integrals in the complex k plane using contour integration. Review the residue theorem and some examples of how to use it and then take another look at the problem.
Thank you so much! would the residue then be e-ax/2ai ?
Something like that, yes. If you want more detailed help you should tell us how you got it. What did you get for the integral?
well, as I am not well-versed in complex analysis I looked up residue theorem and found an example on wikipedia which I modified to fit my situation. The work is as follows
-∞dk (1/(k+ai)-1/(k-ai)) e^ikx
Which has a singularity at ai=k
so Res k=ai = (e^ikx)/2ai
so I multiply by 2*pi*I to get (pi*e^-ax)/a
and then put an absolute value on the "ax" which comes from integrating along the bottom of the arc of the line integral
Does this make sense? is there somewhere I can start to understand exactly how line integrals and residue theorem works?
You've left out a lot of the details, and in the first line the integrand should be exp(ikx)/((k+ia)(k-ia)) but yes that's it. I don't have any favorite references, but you can probably find a lot more examples on the web or in books on the subject of applied mathematics.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
