How Do You Calculate the Area of a Submarine Window from Its Diameter?
  • Thread starter Thread starter zuN
    Pressure
To calculate the maximum safe depth of a submarine window with a 40.0 cm diameter and a force resistance of 1.10x10^6 N, the pressure equation p = F/A is used. The area is determined from the diameter, while the thickness of the window does not factor into this calculation. The atmospheric pressure can be omitted since the submarine maintains internal pressure at 1.0 atm. Using the corrected density of seawater (1025 kg/m³) and gravitational acceleration (9.81 m/s²), the maximum depth is calculated to be approximately 870.5 m. The discussion confirms the accuracy of these calculations and the values provided.
zuN
Hi i need some help with a problem: A submarine has a 40.0cm diameter window 8.50cm thick. The window can withstand forces up to 1.10x106 N. What is the submarine's maximum safe depth?
The pressure is maintained at 1.0atm and it's in salt water.
Salt water density = 1025 kg/m3.
the equation that i used was p = patmos + \rhogd
p = 1.013x105 + (1.0253)(9.8)(d)
What i did to try to find p was p = F/A. <---- If this equation to find pressure is correct, how to I calculate the area from diameter and thickness?
Thanks.
you can omit the first term (atmospheric pressure) because the sub inside pressure is maintained at atmospheric pressure, such that it will cancel out this piece. On your second term, you have a typo, it's 1.025(10^3)(9.8)(d), where d is the water depth in meters
this equation is correct, you need to find the area based on the window diameter; the thickness does not enter into the equation, so you don't need it (that is, the thickness doesn't affect the force on the window, just it's strength, which is not part of the problem.
so if i omit the atmospheric pressure then it'll be p = 1.025(10^3)(9.8)(d) now
p = F/A = 1.10(10^6) / (pie)(0.04) = 8.75(10^6) Pa.
8.75(10^6) / 1.025(10^3)(9.8) = d
d = 871m. answer was 868.
thanks for the help Phanthom Jay
Your answer looks correct. Did the problem give the density of seawater as 1025 kg/m^3 or did you assume that? Using the same values as you, with the exception of g being 9.81 m/s^2 I get 870.5 m.
CS
CS
The professor gave me the value for seawater as 1025 kg/m^3.
