How can I make my wheel motor electromagnets stronger for a high school project?
To strengthen electromagnets for a wheel motor project, increasing the number of wire turns and using a suitable iron core are essential. Salvaging parts from auto components, such as solenoid cores and starter motors, can provide effective materials. Using a motorcycle rear wheel is suggested for its lightweight and broad rim, which is ideal for mounting magnets. Additionally, controlling the electromagnets with a stepper motor controller is considered a viable approach. Further exploration of electromagnetism principles is recommended for better results.
Decoherence
I'm doing an independent study for high school, and my project is to build a wheel motor such as the one pictured http://www.popsci.com/files/imagecache/article_image_large/files/articles/hiw_hybrid_infog_485.jpg" (though less complex, obviously). Essentially what I'm trying to do is to make an inverted stepper motor, with the electromagnets on the hub and the permanent magnets on the rim. As my knowledge of electromagnetism is fairly limited, I've been having some trouble making electromagnets strong enough to influence the magnets on the rim. I know the basics of electromagnets (ie. more turns = stronger field, using an iron core), but so far I haven't been able to get the field strength that I need.
At the moment, I'm using the 30-gauge wire from http://www.radioshack.com/product/i...et+wire&origkw=magnet+wire&parentPage=search", but I haven't been able to find a good core material around where I live. Any advice on where to get good iron cores or general advice about making the electromagnets stronger would be greatly appreciated.
In addition, I plan on controlling the electromagnets with a stepper motor controller; is this a decent idea?
With respect if you attempting products such as this you should start by learning more about electromagnetism and about the various types of motors. I think most electric traction.. cars or TGV trains have moved to over to 3 phase AC induction motors and the 3 phase is electronically generated from DC or single phase AC,
Hi,
Sounds like a fun project! You can get some good magnets and cores by salvaging auto parts. Solenoid cores are usually either iron or steel, and any starter motors will have decent magnets and coils in them. There is a hefty solenoid on most car ignition systems, or the door lock on many washing machines.
I don’t know from your post if your making a proof of concept or the real deal, but if your having problems producing enough force to turn the wheel, then you may consider using a motorcycle back wheel instead as they are lightweight with a broad rim to mount your magnets on. (Its a sad fact that the rear wheel on motorcycles usually survives a crash so they are not hard to get).
Can you post up some pictures of what you have to work with already?
Utwig
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
