How Long to Decelerate in Water with Drag Force?
The discussion focuses on calculating the time it takes to decelerate in water under a drag force, given an initial speed of 7.0 m/s and a mass of 75 kg. The drag force is defined as F_D = (-1.00×10^4 kg/s) * v. The user struggles with determining the correct velocity to use in the drag force equation, leading to incorrect calculations and an unusually high acceleration value. After multiple attempts and reviewing similar threads, the user concludes that the correct time to reach 2% of the original speed is approximately 0.035 seconds. This solution may be relevant for others facing similar physics problems in Mastering Physics.
Cmur
You dive straight down into a pool of water. You hit the water with a speed of 7.0m/s, and your mass is 75kg. Assuming a drag force of the form F_D = (−1.00×10^4kg/s)*v, how long does it take you to reach 2% of your original speed? (Ignore any effects of buoyancy.)
F_D = (-1.00*10^4kg/s)*v
F_g = m*g
F_net = F_D - F_g
(V_f - V_i) / a = t
I have tried various attempts at this solution, all of them giving the wrong answer, and I have one chance left at the question before it gives me 0%. I assumed the general approach would be as follows:
V_i = 7m/s
V_f = 0.14m/s
m = 75kg
F_g = 735N
F_D = (-10000*v) - this part is confusing me, as I'm unsure which velocity value to use, but I have come up with 68600N using the change in initial velocity and final velocity.
F_D = (-10000kg/s * (0.14m/s - 7m/s) = 68600N
Given that F_Net = 68600N - 735N,
m*a = 67865N
a=904.8667m/s^2 (this value seems incredibly large, suggesting I have done something wrong at this point)
Anyways, plugging into my kinematics equation supplied, I get: (0.14m/s - 7m/s)/-904.8667m/s^2 = 0.00758s.
This answer, obviously, is quite wrong. Which value of velocity should I be using in the F_D formula?
I suppose I may as well point out all the answers in time that I have tried, all of which were wrong:
0.0074 seconds
0.37 seconds
0.014 seconds
0.0076 seconds
0.77 seconds
Well, I decided to give one last try at it after reading a similar thread, and it turns out the answer is actually 0.035 seconds to slow down. Seems very absurd, but anyone else with the same Mastering Physics question may as well try this answer.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
