Supernova gravitation field and Newton
The discussion centers on the gravitational effects following a supernova explosion that leaves behind a black hole and a neutrino shell. It explains that the gravitational field inside the expanding spherical shell of neutrinos would be altered by the newly formed black hole, while outside the shell, the gravitational influence remains unchanged, adhering to Newton's Shell Theorem. The change in mass distribution occurs over time, indicating that the gravitational field will evolve as the mass disperses. Additionally, the conversation touches on whether Newton could have deduced the finite speed of light, suggesting that observations of celestial phenomena, such as those made by Cassini and Roemer, could have led him to this conclusion. Overall, the interplay between gravitational fields and the nature of light velocity is explored through historical and theoretical lenses.
zankaon
If a 10 solar mass star explodes, leaving behind a 5 solar mass black hole, and blowing off an idealized spherical symmetrical (5 solar mass) neutrino shell, would the gravitational field (i.e. curvature of manifold) change? http://en.wikipedia.org/wiki/Supernova
p.s. addendum: could Newton have determined that velocity of light was finite?
Astronomy news on Phys.org
Depends on where you're talking about. Far outside = still Schwarzschild, inside is a 2 shell system of different mass/energy density/distribution/pressure.
The gravitational field (curvature) of manifold patch, inside of outward expanding idealized spherical shell of matter, would be affected by newly formed 5 solar mass BH only. This is an example of Newton's First Theorem: A body inside a spherical shell of matter is not gravitationally affected by mass of such spherical shell i.e. no gravitational force is felt. So gravitational field has changed for inside of spherical shell of neutrinos. In contrast, a body outside of such spherical shell, would feel gravitational force (i.e. curvature) as if all of mass were concentrated at center of such spherical shell. Thus 10 solar mass gravitational effect. Hence curvature (i.e. gravitational force) has not changed for outside of such shell. The latter is an example of Newton's Second Theorem. See Shell Theorem. http://en.wikipedia.org/wiki/Shell_theory Realistically only about 10% (?) of mass is carried off by neutrino symmetrical expanding shell.
Also the change in distribution of mass would occur over a finite time (finite velocity); hence the gravitational field (i.e. curvature, deformation of manifold) would change over a finite time.
In regards to addendum: if Newton had been exposed to a clear ordinary glass with a spoon, stirrer etc. in it, his analytical mind probably would have surmised that velocity of light was finite; not infinite, since a change in velocity has occurred for a different medium.
The Italian astronomer Cassini noticed that the times of the eclipses of Jupiter's moons seemed to vary by a few minutes depending on whether the Earth was on the near side or far side of its orbit, and published a short paper on this in 1675. The Danish astronomer Ole Roemer refined these measurements and published calculations which meant that one could estimate the speed of light in terms of the Astronomical Unit (roughly speaking the radius of the Earth's orbit) which was not yet determined, but had been given an approximate value by Cassini. That means that it would have been possible for Newton not only to be be aware that the speed of light was finite, but to have a reasonable idea of its magnitude.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
