How do I graphically add vectors with assigned values and angles?
To graphically add vectors A, B, and E, place them tip-to-tail, ensuring their angles are considered. Vector A has a magnitude of 3.0, vector B also has a magnitude of 3.0 at a 90-degree angle, and vector E has a magnitude of 5.0 at a 45-degree angle. The angles significantly affect the resultant vector's direction and magnitude, which cannot simply be summed as 11. After arranging the vectors, draw a line from the tail of the first vector to the head of the last vector to find the resultant vector. The task requires both the magnitude and direction of the resultant vector.
glindawantsme
Graphically add the following sets of vectors. (There is a group of 6 vectors labeled A-F. They have an assigned value and are at different angles, but the angle is not given)
None?
So my problem here is this. The problem I need help with is adding 3 vectors. The first is A, which has a value of 3.0. Then B, which is also 3.0 but at a 90 degree angle. And the third is E, which is 5.0 and at a 45 degree angle.
I understand that you place them tip-to-tail and then add, but I'm not sure how to do it graphically? Do the angles play a role, or is my answer just 11? PLEASE HELP!
Is it wanting the magnitude and direction of the resultant vector of A + B + E?
It just says "Graphically add the following sets of vectors." I would think it would want the direction but I could be wrong... But it doesn't give the angles (I had to use a protractor) and usually my book does if it wants direction.
Well, if it wants you to graphically add them you can simply put the tail of one vector on the head of another vector and repeat for the third vector. Then, draw a line from the tail of the first vector to the head of the last vector. Since it only asks for the graphical addition I have to assume that's all it wants.
None?
Your answer is definitely not 11.
A vector pointing North? A vector pointing East? And 1 pointing North East?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
