Calculating Engine Characteristics
  • Thread starter Thread starter get2kool
    Engine
To calculate the power and torque needed for a vehicle weighing 200kg to travel at 25mph, consider aerodynamic drag, rolling resistance, and mechanical losses. Aerodynamic drag is determined using the formula F = 0.5 * ρ * v^2 * A * C, where ρ is air density, v is velocity, A is the frontal area, and C is the drag coefficient. Rolling resistance can be approximated with F = C * N, where C is the rolling resistance coefficient and N is the normal force. Mechanical losses are complex and best estimated empirically. The total power required is the sum of all resisting forces multiplied by the vehicle's velocity.
get2kool
I need to figure out how much power and torque my engine has to produce to move a vehicle at 25mph. Can you tell wat all factors i have to consider and the formulae to calculate them?Weight of the vehicle is 200kg. tire width is 90mm and dia = 16"
Moving at a constant speed of 25mph needs enough power to overcome aerodynamic drag, rolling resistance of the tyres, and mechanical losses in the drivetrain.
Aerodynamic drag is calculated using F = 0.5*p*v^2*A*C, where p (is supposed to be a rho!) is density, v velocity, A the frontal area of the body, and C the drag coefficient. Use SI units.
Rolling resistance is much more difficult to calculate accurately, but a reasonable approximation can be given by F = C*N, where C is the rolling resistance coefficient, and N the normal force applied.
Mechanical losses are very difficult to calculate, and an empirical estimation would be safest.
Power is force x velocity, so in this case, the power required to move at a constant 25mph is the sum of all the forces resisting motion multiplied by the body's velocity.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
