How Does an Impulse Affect Amplitude and Frequency in Oscillatory Motion?
The discussion centers on the effects of an impulse on a block attached to a spring, specifically how it alters amplitude and frequency in oscillatory motion. Initially, the block has a mass of 200g, an amplitude of 3 cm, and a frequency of 2 Hz. After an impulse increases its speed by 0.5 m/s, the total energy of the system must be recalculated to determine the new amplitude, while the frequency remains unchanged. Participants emphasize the need to calculate the initial velocity at equilibrium and the new total energy to solve for the updated amplitude. The conversation concludes with a suggestion that the remaining variables can be resolved using the known values.
dsptl
* A 200g block attached to a horizontal spring is oscillating with an amplitude of 3 cm and a frequency of 2 Hz. Just as it passes through the equilibrium point a shalock so trp blow exerts a force impulse on the that the speed of the block is increased by .5m/s. What are the new a) frequency and b) amplitude?
My Attempt:
total energy of the mass moving with amplitude A and oscillating with frequency f will be
E = mA^2ω^2 / 2
where ω = 2πf
f = frequancy of oscillation
A = amplitude of oscillation .
at the mean postion the total eneregy will be in kinetic energy form
E = mv^2 / 2
v =velocity of the mass at equalibrium
if 0.5m/sec is added to velocity
Now the new total eneryg
E' = m*(v + 0.5)^2 / 2 .
m = mass of the block
E' = mA'^2 ω^2 / 2
the frequancy remains constanat
and the amplidue to of the new oscillation changes
ω = 2E' / mA'^2
but at the end I am left with 2 unknown and i am not to solve this
please help its urgent
Hi dsptl,
My Attempt:
E = mA^2ω^2 / 2
where ω = 2πf
E = mv^2 / 2
That's right; so what is the speed of the mass at the equilibrium point before the force impulse add the 0.5m/s? Then you will be able to find the value of the energy after the force impulse. What do you get?
E = mA^2ω^2 / 2 = (.2)(.03)^2(4pi)^2 / 2 = .0142J
where ω = 2πf
E = mv^2 / 2
.0142 = .2 v^2 /2
v = .377m/s
if 0.5m/sec is added to velocity = .377m/s + .5m/s = .877m/s
Is this right till this point? after this point I have no idea what to do...
E' = mA'^2 ω^2 / 2
where ω = 2πf
E = mv^2 / 2
.0142 = .2 v^2 /2
v = .377m/s
E' = mA'^2 ω^2 / 2
Perhaps I'm not understanding what you're asking, but you now can solve for A', since you have everything else.
