What is Steady State Torque and How is it Calculated?
Steady State Torque, also known as Operating Torque, refers to the torque produced by a system when it reaches its operating speed under steady conditions. Calculating it typically requires detailed information about the specific application, including load characteristics and system parameters. The discussion emphasizes that without additional context, providing a precise calculation method is challenging. Participants highlight the importance of understanding the application to derive accurate torque values. Overall, more information is necessary for effective assistance in calculating Steady State Torque.
mselak500
Can someone tell me what Steady State (Operating) Torque is and how to calculate it?
I'm guessing that it is the troque at operating speed.
Any help would be appreciated.
Thanks,
It isn't something easily calculated unless the specific application lends itself to it. You'll have to give us a whole lot more information if we are to be able to help you.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
