What Do These Symbols and Scopes Mean in Mathematical Notation?
  • Thread starter Thread starter transgalactic
    Mean
The discussion revolves around understanding mathematical notation, specifically the meaning of double lines used for absolute value and the significance of brackets in vector notation. Participants are exploring concepts related to norms and inner products in vector spaces.
  • Conceptual clarification, Mathematical reasoning
  • Participants are attempting to clarify the definitions of the double line notation for norms and the bracket notation for spans of vectors. Questions about the implications of these symbols in different contexts are raised.
Some participants have provided definitions and explanations regarding the symbols in question, while others are working to comprehend the material. There is an acknowledgment of the complexity of the inner product and its relationship to the norms discussed.
Participants are navigating various interpretations of mathematical symbols and their applications in vector spaces. The discussion includes references to definitions that may vary across different mathematical fields.
The double line absolute value is called the norm of a vector. Depending on the field, you might have different definitions. See http://en.wikipedia.org/wiki/Norm_(mathematics )
The second symbol, the brackets, are used to denote the span of two vectors. That is the set of all possible linear combinations of two vectors
found it
i will try to comprehend this stuff
Caution: <a, b> is also often used to mean the inner product of two vectors. In fact, since you refer to it in connection with ||v||, I would be inclined to suspect that is what is meant: ||v||2= <v, v>.
The inner product on a vector space, V, is a function from [itex]V\times V[/itex] to the underlying field, such that
1) [itex]<v,v>\ge 0\/itex] and [itex]<v,v>= 0[/itex] if and only if v= 0.<br /> 2) [itex]<au+ bv,w>= a<u,w>+ b<v,w>[/itex].<br /> 3) [itex]<u,v>= \overline{<v,u>}}[/itex].<br /> (that overline is complex conjugate)<br /> <br /> If you are given a basis,[itex]{e_1, e_2, \cdot\cdot\cdot, \e_n}[/itex] for the vector space, so that two vectors, u and v, can be written [itex]v= a_12_1+ a_2e_2+\cdot\cdot\cdot+ a_ne_n[/itex] and [itex]u= b_1e_1+ b_2e_2+ \cdot\cdot\cdot+ b_ne_n[/itex] then the dot product, [itex]u\cdot v= a_1b_1+ a_2b_2+ \cdot\cdot\cdot+ a_nb_n[/itex] is <b>an</b> inner product.[/itex]
so if i have vector a=(x,y,z) b=(s,t,d)
||a||=(x^2 + y^2 +z^2)^0.5
<a,b>=x*s + y*t + z*d
(<a,a>)^0.5 =||a||
is it correct?
Yes.
