Projectile Motion: Diver's Leap from a Tower with Vector Components
A diver leaps from a tower with an initial horizontal velocity of 5.0 m/s and an upward velocity of 2.0 m/s. After 1 second, the horizontal velocity remains constant at 5.0 m/s, while the vertical velocity is calculated using the formula v = u + at, resulting in a final vertical velocity of -7.8 m/s due to gravitational acceleration. The discussion emphasizes the importance of using the correct equations for projectile motion, particularly in separating horizontal and vertical components. Participants clarify the application of these equations and the significance of understanding the effects of gravity on vertical motion. The conversation highlights the need for a solid grasp of physics principles to solve such problems effectively.
ahrog
A diver leaps from the top of a tower with an initial horizontal velocity of 5.0 m/s and an upward velocity of 2.0 m/s. Use a vector diagram to indicate the diver's horizontal and vertical velocity components 1.0s after he leaves the tower.
x=vxt
y= vyt + 1/2gt2
maybe v=d/t
I'm not exactly sure how to go about this problem. Do I just use the x and y formula, and that is all?
Vx= x/t
=5/1
=5
Vy= (y-1/2gt2)/t
=(2-1/2(9.8)(1)2)/1
=-2.9
Would those be right?
Not quite right. The best equation to use here is v2 - v1 = a(t2 - t1). So for vx, a =0 and v2 = v1 = 5. (as you said). For vy, a = -9.8 and v2 = 2 - 9.8 = -7.8.
Really? They haven't mentioned that formula in what I've done so far...
I had never witnessed such a formula either till it clicked - it's just a slight modification to the v=u+at formula.
where:
v = final velocity
u = initial velocity
a = acceleration due to gravity
t = time
And yes, this is the best formula to use in this case. Horizontal velocity will be kept constant at 5ms-1 since we are assuming no resistances, so you already know what that vector is going to be after 1 second. Now you just need to calculate the vertical vector with this equation, which ak1948 already gave as -7.8ms-1.
