Statistics Expected Variable Question
To calculate the expected value E(Y) when two fair dice are thrown, Y represents the larger score of the two dice. There are 36 possible outcomes when rolling two dice, and for each outcome, the larger number needs to be identified. The expected value can be found by summing the larger numbers from all pairs and dividing by 36. It is important to note that in cases where both dice show the same number, either number can be considered as the larger one. This approach will yield the correct expected value for Y.
thomas49th
Y is the larger score showing when two dice are thrown
Calculate E(Y)
Presume the dice are fair
Hmm not sure. I've listed combinations of throw events on paper but I don't think that will help. Y can never be 1. Y can never be the same as the other die?
Do I want to draw a probability distrubution table?
I've been messing around with it for a while with not much progress
If both dice come up with 1s, if you don't count the 1, you won't have anything to count for that roll.
With two dice, there are 36 possible outcomes: {(1, 1), (1, 2), ... , (1, 6), (2, 1), ... (2, 6), (3, 1), ..., (3, 6), (4, 1), ..., (4, 6), (5, 1), ..., (5, 6), (6, 1), ..., (6, 6)}.
I think that for the expected value of Y, E(Y), you add together the larger number in all 36 pairs, and divide by the number of pairs, which is 36. For the 6 pairs that have the same value, pick either number to be the larger; it's certainly not the smaller of the two.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
