Need help with partial fraction decomposition for inverse Laplace?
  • Thread starter Thread starter rforrevenge
    Fraction Partial
rforrevenge
I want to decompose this (s+2)*(s+1)/(s+2)*(s+1)*(s^2+1)-1 using partial fractions so after that i can inverse Laplace it. I have been working on it for several hours but i cannot find a solution. Any help?
Use parentheses so that it is clear what the expression, in particular what the denominator, is. Is it: (s+2)*(s+1)/[(s+2)*(s+1)*(s^2+1)] - 1? Presumably not, as trivially (s+2)*(s+1)/[(s+2)*(s+1)*(s^2+1)] - 1 = 1/(s^2+1) - 1.
The fraction is: (s+2)*(s+1)/[(s+2)*(s+1)*(s^2+1)-1]
The -1 is a part of the denominator
Thanks for clarifying, rforrevenge. The denominator (s+2)*(s+1)*(s^2+1)-1 doesn't appear to factorise, so no partial fraction decomposition is possible. Check your work up to arriving at, presumably, Y(s) = (s+2)*(s+1)/[(s+2)*(s+1)*(s^2+1)-1]. Perhaps show us how you arrived at it.
Are you sure you've copied down the correct expression? The denominator expands to s^4+3s^3+3s^2+3s+1 which has no real roots/factors.
Yes i am sure.I found out that the denominator has no roots,so there must be some problem with that expression our prof. gave us
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
