What is the equation for capacitance of a coaxial cable?
The discussion focuses on deriving the equation for the capacitance of a coaxial cable per meter length, emphasizing the use of Gauss's law. The participants note that the standard capacitance formula for parallel plate capacitors is not applicable here. The correct capacitance formula is identified as C = (2πε) / ln(R2/R1), where R1 and R2 are the inner and outer radii, respectively. The approach involves integrating the electric field derived from Gauss's law to find the potential difference. The conversation highlights the need for proper integration techniques to arrive at the final capacitance expression.
jumpboy
http://smg.photobucket.com/albums/v68/jumpboyb/?action=view&current=scan0001.jpg"
Pretty much looking for a general equation for capacitance of a coaxial cable per meter length.
given:
-a diagram (click link)
-two radii
-dielectric material
-outer conductor is grounded (V = 0V)
C = Q/V
C=A/d\epsilon0
used the second equation but won't work since its for a parallel plate capacitor.
thats it! I'm lost on this one
I think the best way to approach this problem is with Gauss's law. You need to set an arbitrary charge (it will vanish in the end.). Use a cylinder as your Gaussian surface. Hope this helps
Still stuck. Here's what I did with Gauss' Law in mind. (btw, the answer is (2pi\epsilon)/ln(R2/R1) and that's not pi to the epsilon not power btw.)
So, with Gauss, you have integral of E dot dA which equals Q/\epsilon.
Capacitance - Q=VC...so subsitute that back into the gauss equation so you have...
EA = VC/epsilon \Rightarrow C= EA[epsilon]/V
Electric potential is the negative rate of change of a electric field...ie E = -dV/ds = -V/r where r = R2 - R1
C=-rA[epsilon]=-2pi(r)3[epsilon]
and yea...nothing. I see I need to integrate something, but idk where or what logic to use for it.
To get V you must integrate the expression for E with respect to dr. You can't just use E = -V/r which is true only for the simplest 1D case.
Right, try adding the integral of E dot dl or dr (whatever you guys call it.) into your arsenal.
the expression you want to integrate is dV = -[Q/(2Pi*R)] with limits from R1 to R2 (inner to outter). This is obtained through gauss's law, saying that EA = Qin/Episilon, solving for E and substituting for the original integral of dV = -[E dot ds]. The area "A" is 2*Pi*r because after the length is taken into acount, it will account for the surface area.
