Query on physics of a tennis ball
The discussion focuses on the energy transformations of a tennis ball when dropped, specifically gravitational potential energy (GPE) converting to kinetic energy (KE) during the fall. Upon impact, the ball loses some KE to heat and sound, and the energy stored in the ball's compression, akin to elastic potential energy (ePE), allows it to bounce back. The bounce height is influenced by the ball's internal pressure; a well-inflated ball compresses less upon impact, resulting in less energy loss and a higher bounce. Additionally, heating the ball increases its internal pressure, potentially enhancing its bounce. Understanding these energy dynamics is crucial for grasping the physics behind a tennis ball's behavior.
Confuzzled
As title reads...
In my As physics class today the topic of this arrived, which has been annoying me ever since, i am hoping you may be able to help, as hours of searching the internet i have failed. :(
I understand that when a ball is held at a certain height that it has stored energy, GPE. And when this ball is dropped this energy turns into Kinetic Energy, my query is on what is the energy, at the point it hits the ground? I would assume elastic energy, but am unclear.
Also if this said ball was to be heated, I it would bounce a higher distance due to temperature being proportional to pressure? And pressure being the answer to how much something would bounce? But why is this? What does pressure do to the insides of that tennis ball?
Thanks Confuzzled
As the ball is falling, the gPE 'turns' into Kinetic, Heat and Sound energies (albeit, the last two are slight in comparison).
Similarly, when the ball hits the ground, it 'loses' Kinetic energy to more heat and sound, and indeed as you said ePE.
Conservation of energy means that the ball will not bounce higher than the height you dropped it from, unless you some how superheated it during it's fall.
The question about pressure is interesting; think about it in your every day life. A poorly inflated basketball does not bounce nearly as well as a well inflated one, why?
The answer relates to your first question, I think. We can easily analyze the fall of the tennis ball as a straight conversion between gravitational potential energy and kinetic energy. However, when the ball hits the ground KE is zero and PE is zero, so how can it bounce back? The ball behaves (roughly) like a spring in that it is compressed and stores energy, which it releases and bounces back up. However, a tennis ball is by no means a perfect spring so the more the compression, the greater the loss of energy due to heat, sound, and other external factors.
So, when you have a tennis ball with high internal pressure, as it hits the ground it has a much higher "spring constant", i.e it will compress far less and thus suffers less loss due to external factors and will bounce back with a height closer to that of the original.
Hope this makes sense!
Cheers
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
13K
