- #36
debra
- 125
It seems to me that the crux of the matter is to decide if entangled electrons passing through a magnetic field removes the entanglement effect between the electrons.
Dbar_x said:... The cruicial question, I think, is not whether photons and atoms both exhibit interference, but what exactly constitutes a quantum measurement, and what doesn’t. The question has definitely not been settled by physicists, resulting, I believe, in the continued confusion in quantum theory. Many measuement theorests today claim, for example, that what we do or do not know is an essential ingredient in the measurement process. Some, including Kwiat, have written that knowledge and the visability of interference are complementary variables in the Bohr theory (of complementarity). I think that the quantum theory, like all other physical theories, must be observer independent.
Obviously, I believe that the spin direction of silver atoms exiting a S-G magnet has been measured, so resulting in each atom going either one way or the other, not both. There is no experimental evidence of S-G interference, or anything else, yet, to refute or confirm my contention. That includes all the photon interference experiments.
If the atoms from a S-G magnet had not been measured, and actually remained in a spin superposition, there would not be the two separated traces left on the detector. If the atom continued in its spin supeposition it would be kicked back and forth, randomly, by each quantum in the macroscopic field, and would emerge still centered on the magnet, not at one of two separated spots. Instead, the measurement is amplified by each successive quantum exchange, certainly not something done in a photon beam splitter. A beam splitter cannot record (or register, or measure) which way the photon went. If it did measure which way, the photon would be reduced to just one path, with no interference.
Particle no entangling after magnet field. We know this. Many wrong thing in theory - no good.
And again, what sort of experimental result would it take to convince you that you are wrong about this?Dbar_x said:believe the crux of the matter, Debra, is whether the S-G magnet is the measuring apparatus which reduces the particle’s spin superposition to a single eigenvalue. I’m convinced that no detector screen is necessary.
some sort of erasure of the which-path information which according to orthodox QM should allow us to observe an interference pattern
I don't know anything about the specifics of that particular experiment, but are you claiming that all quantum eraser experiments can be explained in a classical way? What about the delayed choice quantum eraser, for example?
I think you are asking WHEN is the observation to have occurred, and I can see your point that this is not specified precisely in current theory.
Let’s recall the history of physics. Galillean relativity is fundamental to all of classical physics. Einstein’s special and general theories are founded on the basic notion that all the laws of science are covariant. Form invariant, that is, in the reference frame of every observer. Does it make any sense to discard observer independence because some of the many, contradictory, proposed theories of quantum measurement require observer dependence?I don't fault anyone for believing in observer independence, mind you,
what would you consider a valid experimental demonstration that the electron is indeed in a superposition of states after leaving the SG device (but before its deflection angle is measured by us)? The only way I can think of to demonstrate superposition experimentally is to show that some type of interference effects can be measured...
Can you elaborate on why you think quantum erasure would require "reversible measurement" or mixtures evolving from superpositions? The delayed choice quantum eraser involves the "signal" photon that goes through the slits being entangled with an "idler" which can tell you which slit the signal photon went through if it goes to one set of detectors (D3 or D4 in Scully's paper) but this information will be lost if it's detected at a different set of detectors (D1 or D2). If the signal photons are detected first, then you could use the 2-particle wavefunction for the signal/idler pair to calculate the probability distribution for just the signal photon to end up at different points on the screen; if the idlers are detected first, then according to the standard procedure for calculating probabilities this would cause a discontinuous collapse in the 2-particle wavefunction which would alter the probabilities of the signal photon landing at different points on the screen. However, I presume that if you calculate P(signal photon detected at position X|idler detected at detector D1)*P(idler detected at detector D1) + P(signal photon detected at position X|idler detected at detector D2)*P(idler detected at detector D2) + P(signal photon detected at position X|idler detected at detector D3)*P(idler detected at detector D3) + P(signal photon detected at position X|idler detected at detector D4)*P(idler detected at detector D4), then you should get almost exactly the same answer as you'd get for P(signal photon detected at position X) in the case where the signal photon is detected first so there was no prior state reduction in the 2-particle wavefunction caused by the detection of the idler (I say almost exactly because there may be cases in which the idler just misses all 4 detectors, but you should be able to make it exact by adding additional detectors so that there was no possible direction the idler could go without hitting a detector).Dbar_x said:I don’t think, JesseM, that information erasure at the detector, causing interference restoration, is orthodox quantum mechanics. What’s the basis in theory? There can be no reversible measurement via Schrodinger development; mixtures do not continuously evolve from superpositions.
Required for what, exactly? I'm specifically asking for an experiment that could falsify your claim that the atoms are not in a superposition after traveling through the SG device, not one that you think would "prove" that claim (if you're thinking of the latter type of experiment, it may be that your idea of proof is based on a misconception, and that in fact orthodox QM would predict exactly the same result that you predict even if we assume the particle does remain in a superposition after passing through the device, with the collapse not occurring until we actually detect its position). So, are you in fact thinking of an experiment that would falsify your claim, and that would provide evidence that the atom was in a superposition after it passed through the SG device?Dbar_x said:No interference pattern is required, JesseM. Contact me via e-mail if you’d like to discuss the experiment.
Dbar_x said:I believe the crux of the matter, Debra, is whether the S-G magnet is the measuring apparatus which reduces the particle’s spin superposition to a single eigenvalue. I’m convinced that no detector screen is necessary.
DocMike
this information will be lost if it’s detected at a different set of detectors (D1 and D2).
OK, so particle not interfere with itself after go out from magnet field. Screen show no interference. You want proove this - yes / no?
But presumably any calculation that shows that erasing the information from the detector would "restore the interference fringes" depends on modeling the detector's interaction with the particle as creating an entangled detector/particle system rather than the detector collapsing the wavefunction.Dbar_x said:Marlan Scully is the father of quantum erasure. His mathematical analysis from 1978 with Shea and McCullen is the genesis of all the QE experiments that have followed. So, let me quote from an article by Scully and Walter, “An Operational Analysis of Quantum Eraser and Delayed Choice,” Found. of Phys. 28, 3, 1998. On p. 400 they say, “...if we put a Welcher Weg detector in place (so we lose interference even if we don’t look at the detector) and then erase the which way information after the particles have passed...such a ‘quantum eraser’ process (would) restore the interference fringes.” (Notice that in this instance QE is described as observer independent, since the detector is responsible for destroying interference whether or not any person is looking.)
Have you studied at the actual mathematical analysis of how erasing the information in the apparatus is supposed to restore interference? Again, I would assume that such an analysis would not involve the assumption that the detector caused a collapse of the wavefunction when it made the original measurement, but would instead model the detector as becoming entangled with the particle it measured, would then show that if you don't assume the detector's state is measured (and its wavefunction collapsed) until after the which-path information has been erased, in this case you can show there will be interference effects in the system. Think about how the situation would be analyzed if you treat the idler as a miniature "detector" which carries information about which path the signal photon went through, but where the idler's information can later be erased if it is measured in a certain way--I'm pretty sure you don't assume that when the signal photon passes through the slits, the which-path information potentially available in the idler causes an immediate collapse of the 2-particle wavefunction!Dbar_x said:The detector is a measurement apparatus and the measurement destroys the interference. Measurement implies a single real eigenvalue for the property observed; which path in this case. So, the density matrix is diagonalized. Von Neumann showed that diagonalization of the density matrix is a thermodynamically irreversible process. But, by erasing the information now stored in the apparatus, QE is supposed to restore interference. That’s a reversal of the measurement.
But that's just the sort of situation the words "quantum eraser" are used for! What's "erased" if the idler ends up and D1 or D2 is the potential that existed at earlier times to gain the which-way information by measuring the idler in the right way. After all, if you really want to know the which-way information immediately after the signal-idler pair are created, you can always guarantee that the idler will end up at a detector that gives you the which-way information by altering the experimental setup at that moment--in the diagram of the experiment in Scully's paper, just imagine removing the two beam-splitters BSA and BSB, in which case no photons will be deflected towards D1 or D2, they'll all go to D3 or D4. By making the path length of the idler long enough in comparison to the path length of the signal photon, you could even set it up so you didn't have to decide whether you wanted to have a guarantee of getting which-path information (by putting nothing in the spot of BSA and BSB so all the idlers go to D3 or D4) or if you wanted to have a guarantee of no which-path information (by putting mirrors in the spots of BSA and BSB so all the idlers go to D1 or D2) until after you'd already detected the signal photon at D0. If you make the latter choice, I'd assume Scully would deem this a choice to "erase" the which-path information.Dbar_x said:As we know, the wavefunction predicts the probability that the idler photon might be absorbed at either D3 or D4 (or D1 or D2). If the idler is not absorbed at D3 or D4 (but at D1 or D2 instead) no information about which way the signal photon went is recorded at a detector. The which way information isn’t erased or lost, it never was.
JesseM said:I'm specifically asking for an experiment that could falsify your claim that the atoms are not in a superposition after traveling through the SG device
That doesn't really make sense to me. If there are two alternative possibilities (in this case, either the atoms are in superposition or aren't after passing through the SG device), then the only way to "falsify" either possibility is to show that they yield different predictions about a given experiment, and then demonstrate one prediction is confirmed while the other isn't. If you don't even know what an advocate of the "atoms do remain in superposition after passing through the SG device" view would predict about your own experiment, how can you possibly say that if the experiment has the results you predict it'd falsify this view? Maybe you're just thinking about it wrong and an advocate of the superposition view would actually predict the same thing you're predicting. And if you do know what they'd predict and it's different from what you predict, then if the actual results matched their prediction but not yours, wouldn't that be a falsification of your own view that they don't remain in superposition?Dbar_x said:You’re asking the wrong person for such an experiment. I know of no experiment that will do it. There is, however, a simple experiment that will refute or falsify the widely-held belief (hypothesis) that the particle remains in its spin-direction superposition through the magnetic field.
The reasons are not obvious to me, you could probably get a lot more useful feedback than you will with your current cryptic approach. If you're afraid you'd run afoul of the rules against challenging mainstream theories, you can just present the experiment as a way of distinguishing the two views on superpositions without making any confident predictions about what the results would be, or asking for feedback about what orthodox QM would predict about your experiment. If you're afraid someone will steal your idea and take credit, then I don't really understand why it would be any better to share it with anonymous users via PM as you have offered to do, and in any case a public post outlining your idea would show that you were the first to publicly propose this experiment.Dbar_x said:No. For what I think are obvious reasons, I’m not willing to discuss details of the experiment in this public forum.
Essentially, yes.
JesseM said:But presumably any calculation that shows that erasing the information from the detector would "restore the interference fringes" depends on modeling the detector's interaction with the particle as creating an entangled detector/particle system rather than the detector collapsing the wavefunction.
If you consider that optically active devices can send electromagnetic "signatures" along the same path that photons go (only in opposite direction) down to BBO then you will have more sensible picture than these secret messages.debra said:Can we believe what they claim in this
reference above? (photons sending secret messages about filters etc).
zonde said:If you consider that optically active devices can send electromagnetic "signatures" along the same path that photons go (only in opposite direction) down to BBO then you will have more sensible picture than these secret messages.
Of course it is not what QM says.
According to the chart on the page underneath the diagram you posted, it's true that some photons going through slit 1 have polarization R, and some photons going through slit 2 also have polarization R...but the ones that have polarization R after going through slit 1 are all matched to entangled p photons that had polarization x, while the ones that have polarization R after going through slit 2 are all matched to entangled p photons that had polarization y. So by matching up each s photon at detector Ds with its entangled p photon at detector Dp, you should always be able to tell which of the slits the p photon went through, so there should be no interference. And you can see on the graph underneath the chart that when they actually performed this experiment and looked at the data, they didn't see an interference pattern:debra said:Isn't it true that a proportion of the photons passing through
both quarter wave plates will have the same polarization - by
probability? - and will interfere normally? Then the filter
labelled Polarizer examines those only. Not exotic at all? I
may be wrong here and its all wrapped up and proved.
I understand your sarcasm but I am taking a bit different approach.debra said:Quantum erasure experiments often speak about backwards in time messages and I was being sarcastic about 'secret messages' even though they actually claim this in the above reference. I am questioning the experimental set up and analysis of results and am hoping the SG discussion in this thread will throw some clarity on these entanglement and beam splitting questions without resorting to FTL and similar exotics.
[/URL]JesseM said:According to the chart on the page underneath the diagram you posted, it's true that some photons going through slit 1 have polarization R, and some photons going through slit 2 also have polarization R...but the ones that have polarization R after going through slit 1 are all matched to entangled p photons that had polarization x, while the ones that have polarization R after going through slit 2 are all matched to entangled p photons that had polarization y. So by matching up each s photon at detector Ds with its entangled p photon at detector Dp, you should always be able to tell which of the slits the p photon went through, so there should be no interference. And you can see on the graph underneath the chart that when they actually performed this experiment and looked at the data, they didn't see an interference pattern:
http://grad.physics.sunysb.edu/~amarch/PHY5658.gif
zonde said:I understand your sarcasm but I am taking a bit different approach.
Say I believe that experimental set up and analysis of results are free from serious errors and I am looking for realistic explanation from that point.
And the only realistic explanation that comes to my mind is that optically active devices interact with photon at the moment of emission with that interaction happening at light speed and not FTL. This interaction at light speed is what I meant with that electromagnetic "signature".
zonde said:And the only realistic explanation that comes to my mind is that optically active devices interact with photon at the moment of emission with that interaction happening at light speed and not FTL. This interaction at light speed is what I meant with that electromagnetic "signature".
Since it is impossible in practice to maintain a macroscopic measuring-apparatus in isolation from its environment and only observe it after enough time has passed that no which-path information would be gained from the observation, we are not dealing with predictions about actual experiments here (in future we might be able to create large isolated multiparticle systems using quantum computers, so this sort of thing is not impossible in principle, just impossible with present technology). But it's routine in theoretical physics to look at what the formalism of a given theory would tell us about an experiment which is impossible in practice for us to do today, like analyzing what would be seen by an observer diving into a black hole in general relativity. In QM, if a system composed of all the particles making up a macroscopic object could be maintained in isolation for some time and then observed, the formalism would say you should set up a giant multiparticle wavefunction for the system and evolve it forward until the moment of observation using the standard rules for wavefunction evolution, and then at the moment of observation you'd use the usual Born rule to figure out the probabilities it will be in different configurations. This is what physicists imagine doing in the Schroedinger's cat thought-experiment for example. It has nothing to do with "quantum erasure" specifically, it's just the universal quantum rules for dealing with any isolated quantum system composed of multiple interacting particles (and this is exactly what's done for smaller isolated multiparticle systems consisting of just a few particles).Dbar_x said:Credible, useful physical theories must be clear and unabmigiuous, consistent, and testable by falsification (or refutation) via experimental observation. As, for example, special relativity or quantum electrodynamics. It’s incumbant on those proposing or supporting a theory to meet such criteria, not on the rest of us to try to figure out what in the world they mean.
If quantum erasure means that entanglement between the apparatus and observed system causes an interference pattern to be destroyed, then restored when information is erased, then it must be clear precisely when the two objects are entangled. What unambiguous definition does QE give for entanglement? Is it distinct from the von Neumann measurement correlation between object and apparatus?
...then it seems a little pointless to waste too much time worrying about an offhand remark about an impossible-in-practice thought experiment similar to Schroedinger's cat (aside from pointing out that your notion that his statement assumes 'mixtures evolving from superpositions' is almost certainly a misreading of what he had in mind). Let's focus instead on the actual quantum eraser experiment, which doesn't involve a giant multiparticle wavefunction, but just a 2-particle wavefunction for the signal/idler pair. In that vein, you ask:...if we put a Welcher Weg detector in place (so we lose interference even if we don’t look at the detector) and then erase the which way information after the particles have passed...such a ‘quantum eraser’ process (would) restore the interference fringes.
"Potential" just means on any given trial, if you choose you can always set up the experiment so that you do gain which-way information on that trial (and if the idler path length is long enough you can make this choice after the signal photon has already been detected). It's similar to saying that on any trial involving a single particle going through the double-slit, prior to the time when the particle reaches the slits there is the potential to gain that particle's which way-information by placing a detector near the slit. You could demonstrate this potential by putting a detector near the slits on 100% of the trials, and in that case for near 100% of particles (allowing for some small amount of experimental error) you would gain the which-way information. Similarly, if you removed the beam-splitters BSA and BSB in Scully's experiment on 100% of trials, for near 100% of signal/idler pairs you could gain the signal photon's which-way information. If you don't like this use of the word "potential", fine, as long as you agree about the basic physical idea that you can set up the experiment so that you gain which-path information on nearly 100% of trials, then this is just a semantic dispute with no real physical content.Dbar_x said:How would an experimenter measure the potential to gain which-way information? What’s the equation for such a potential?
Thank you for your comment!DrChinese said:Experiments have already been done where Alice and Bob's polarizers are changed mid-flight, at a time at which it would be too late for them to have the kind of light speed influence that you imagine. So your "realistic" explanation will not work.
zonde said:Thank you for your comment!
Didn't knew about that Austrian experiment with ultra-fast random analyzer settings (http://arxiv.org/abs/quant-ph/9810080). It was very enlightening to find out about it. I suppose that was the one of the experiments that you were referring to.
Hmm, it would be interesting to know if there are plans to prepare quantum eraser experiments like that with ultra-fast random changing of settings.
zonde said:Still ... in that Austrian experiment there is one small hole. Detection rates with static polarizer settings are not known, at least in paper there is said nothing about something like that.
If for example detection rate with static polarizer settings would rise twice then it's easy to see that sampling can be adjusted so that actual polarization much expected polarization.
I do not say that this is the case but it would be more comforting to discard such possibility.
