Generating using a DC brushed motor
  • Thread starter Thread starter lucy_b14
    Dc Motor
Using a DC brushed motor as a generator involves mechanically turning the shaft to produce electricity. To estimate the potential power output, one should refer to the motor's specifications, particularly the input current at a specified voltage, which can help gauge the output current when generating power. Motors are generally efficient, so only a slight derating may be necessary for accurate calculations. It's important to account for the mechanical power needed to achieve the desired electrical output and to implement a snubber/filter circuit to manage the noisy output typical of brushed motors. Brushless DC motors are an alternative that may reduce output noise but require a more complex control system.
lucy_b14
Good Evening
I'm interested in the possibility of using a DC brushed motor as a generator (ie running it in reverse - mechanically turning the shaft to produce electricity).
However, I have no idea how to calculate the power I could potentially achieve. Any tips or equations in particular would be greatly appreciated.
Thanks
lucy_b14 said:
Good Evening
Thanks
A good start would be to look at the specifications for the motor's normal operation. What is the input current listed for the specified DC input voltage? That will give you a pretty good ballpark idea of what the output current will be when you are turning the motor fast enough to generate the specified voltage. Motors are pretty efficient, so you may only have to derate the motor numbers by a couple tens of percent to get the generator numbers.
Be sure to calculate the associated powers, so you know what kind of input mechanical power will be required to get that output electrical power.
Oh, and the output of DC motors is generally pretty noisy, due to flyback impulses when the brushes are switching. Be sure to plan on an output snubber/filter circuit to clean up the DC output voltage.
Please excuse me if this comment is stupid, but would it not be possible to use a brushless DC motor - and then there wouldn't be an issue of a noisy output signal ?
Ah, You need a more complex control system to run a brushless dc motor correct ?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
