Permanent magnet DC Generator questions
The discussion revolves around the use of a Permanent Magnet DC Generator in conjunction with a compressed air motor for a mechanical engineering project. The generator's output voltage is influenced by load and RPM, with potential outputs of 12, 24, 36, 48, 90, or 120 volts. The user seeks clarification on how resistance affects current and voltage, particularly whether the resistance will self-adjust or if current will adapt to a set resistance. It is suggested that researching Maximum Power Point Tracking (MPPT) could provide valuable insights into managing variable output impedance. Understanding these dynamics is crucial for accurately determining the power output of the pneumatic motor.
Zeph
Hello, I'm a mechanical engineering student currently working on a project which involves a compressed air motor and a Permanent magnet DC generator.
I have this generator :
http://www.windstreampower.com/443905_PMDCG.php
Basically, we'll use the generator power output to determine the power output of the pneumatic motor, with that we can get the amount of air flowing through the motor.
I would like to understand how voltage will be decided. They say "Output Voltages: 12, 24, 36, 48, 90, or 120 (determined by load and rpm)"
The generator will be plugged on a variable resistance
the way I see it is that if the generator runs at 1000rpm, ill get 50Volts(1st graph)
I'd then get around 2.5Amps and 125Watts(graph 2),
would the resistance set itself to 20ohm or would the current adapt to the resistance I set?
thx for clarifying I'm a little bit confused :)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
