Lagrangian mechanics for two springs
The discussion focuses on deriving the Lagrangian for a system of two springs supporting two identical masses. The kinetic and potential energies are calculated, leading to the formulation of the Lagrangian. Equations of motion are established, and matrices for the system are derived to find eigenvalues related to normal modes and frequencies of oscillation. A misunderstanding regarding the gravitational potential energy's contribution is clarified, emphasizing the need for negative signs in the equations. Ultimately, the participant resolves the confusion and confirms their findings, indicating progress in understanding the problem.
wglmb
A spring of negligible mass and spring constant k, hanging vertically with one end at a fixed point O, supports a mass m, and beneath it as second, identical spring carrying a second, identical mass.
Using a generalised coordinates the vertical displacements x and y of the masses from their positions with the springs unextended, write down the Lagrangian.
Find the position of equilibrium and the normal modes and frequencies of vertical oscillations.
KE: \frac{1}{2}m(\dot{x}^{2}+\dot{y}^{2})
PE: mg(l+x)+mg(2l+y)+\frac{1}{2}kx^{2}+\frac{1}{2}k(y-x)^{2} =mg(3l+x+y)+kx^{2}+\frac{1}{2}ky^{2}-kxy
Lagrangian: L=\frac{1}{2}m(\dot{x}^{2}+\dot{y}^{2})-mg(3l+x+y)-kx^{2}-\frac{1}{2}ky^{2}+kxy
Equations of motion:
\frac{d}{dt}(\frac{\partial L}{\partial \dot{x}})-\frac{\partial L}{\partial x}=0 \Rightarrow m\ddot{x}+mg+2kx-ky=0
\frac{d}{dt}(\frac{\partial L}{\partial \dot{y}})-\frac{\partial L}{\partial y}=0 \Rightarrow m\ddot{y}+mg+ky-kx=0
Know that B_{ij}\ddot{q}_{j}+A_{ij}q_{j}=0
\Rightarrow B=\left( \begin{array}{cc}<br /> m &amp; 0 \\<br /> 0 &amp; m \end{array} \right), A=\left( \begin{array}{cc}<br /> 2k &amp; -k \\<br /> -k &amp; k \end{array} \right)
B^{-1}A=\left( \begin{array}{cc}<br /> \frac{1}{m} &amp; 0 \\<br /> 0 &amp; \frac{1}{m} \end{array} \right)\left( \begin{array}{cc}<br /> 2k &amp; -k \\<br /> -k &amp; k \end{array} \right)<br /> =\left( \begin{array}{cc}<br /> \frac{2k}{m} &amp; \frac{-k}{m} \\<br /> \frac{-k}{m} &amp; \frac{k}{m} \end{array} \right)
Eigenvalues turn out to be:
\lambda=\frac{k}{2m}(3+\sqrt{5}) and \lambda=\frac{k}{2m}(3-\sqrt{5})
This doesn't look very likely to be right.
Then when I work out the eigenvectors, I get (0,0) in both cases...
... where have I gone wrong?
When you moved the masses down x and y respectively, the strain energies increased as you have indicated, but the gravitational energies also increase?
Haven't I got that included in the mg(3l+x+y) part of the PE? This comes from mg(l+x)+mg(2l+y) which is mg times the height of the first particle plus mg times the height of the second.
The gravitational potential energy is decreasing with increasing values of x and y, so you need some negative signs.
Ah, I see what you mean - of course! I don't have time just now but I'll work that through later and see how I manage :)
Edit:
Hmm, well I still get the same matrices A and B, since they come from the double-dotted terms and the x&y terms. The constant terms (now -mg for both of the equations of motion) aren't used.
I have a feeling those constant terms shouldn't even be there, since none of the examples we've been given have any...
It's OK, I've figured it out now. Thanks :)
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
