Parabolic Equations Using Vertex & Focus
  • Thread starter Thread starter TheLastLetter
    Focus Vertex
The equation of the parabola with vertex (2, 4) and focus (2, 6) is derived using the formula (x-h)^2 = 4p(y-k), resulting in (x-2)^2 = 8(y-4). There is a discussion on whether to isolate a variable or leave the equation in its current form, with suggestions to group constants for clarity. Dividing through by 8 is mentioned as optional, depending on teacher preferences. The conversation emphasizes that similar to a circle's equation, isolation of variables is not always necessary. The focus remains on understanding the equation's structure rather than strict formatting.
TheLastLetter
Write the equation of the parabola described.
Vertex: (2, 4) Focus: (2,6)
(x-h)^2 = 4p(y-k)
(x-2)^2 = 4(2)(y-4)
x^2-4x+4 = 8y -32
Do I need to isolate one of the variables, or can I leave the equation like this?
I'd at least group your constants, to make it look nicer. After you've done that, you could divide through by 8, but it isn't strictly required (unless your teacher said so). Afterall, an equation for a circle is x^2 + y^2 = 1, and that doesn't have an 'isolated' variable.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
