Solving Billy and Speakers: 16m, 0.8m, 3000 Hz
  • Thread starter Thread starter axgalloway
To determine how far Bill must walk to reach the m=1 maximum of sound interference, the wavelength of the sound needs to be calculated first, which is found to be approximately 0.1143 meters. The key is to identify the point along the wall where the distance from each speaker differs by half a wavelength. This involves applying the geometry of the setup, considering the speakers' positions and the distance to the wall. The solution requires understanding the relationship between the interference pattern and the geometry of the speakers' arrangement. Ultimately, solving this problem hinges on accurately applying these principles to find the correct walking distance for Bill.
axgalloway
Two lound speakers are each located 16m from a wall and are 0.8m apart. They play a 3000 Hz sound, both speakers are in phase. Bill is located at the wall at the m=0 maximum of sound interference. If he walks along the wall, how far does he have to walk to hear m=1 maximum? (The speed of sound is 343 m/s.)
2pi * (x2-x1) / lambda = 2mpi
vsound = lambda*f
343 m/s = lambda*3000Hz
lambda= .1143 meters
Beyond that, I do not know how to solve it.
Thank you.
Sounds like you have a little geometry problem. Don't you just need to find the point away from the mid-line whose distance from each speaker is different by half a wavelength?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
