Is the Otto Cycle Reversible with Ideal Gas Assumptions?
The discussion centers on the reversibility of the Otto Cycle under ideal gas assumptions. It is noted that while theoretically, isochoric processes can be reversible, the overall efficiency of the Otto Cycle is lower than that of the Carnot Cycle, indicating it cannot be fully reversible. The conversation highlights the need for infinitesimal temperature differences between heat reservoirs for reversibility, suggesting that real Otto engines operate irreversibly due to combustion and pumping losses. However, the ideal air standard Otto cycle can be considered reversible since its four processes are theoretically reversible. The complexities of heat addition and pressure changes during the cycle are also debated, emphasizing the nuances of describing these processes.
Harmony
Theoretically, we can have reversible isochoric expansion and isochoric compression. Is Otto Cycle reversible then?
I read that the efficiency of all reversible engine between two heat reservoir would have the same efficiency. However, since the efficiency of an Otto Cycle is lower than Carnot Cycle, it cannot be reversible.
How do I resolve this problem? Thanks in advanced.
Are you referring to the process whereby the hot combustion products are allowed to expand, cool and perform work? Or to the preceding different process whereby chemical potential is let change directly into thermal energy, in a spontaneous (and somewhat uncontrolled in comparison to fuel cells) manner?
I refer to the first process, but a hypothetical ideal one where it is reversible. After some thought, I think that in order for an ideal gas to expand under constant volume and yet be reversible, there will have to be many heat reservoir, with infinitesimal small difference in temperature. Hence the reversible Otto Cycle will not be operating between two heat reservoir.
As for an Otto Engine operating between two heat reservoir, the process must be irreversible.
Is my reasoning correct?
Well a real Otto cycle is in no way reversible as you have the messy business of combustion and pumping losses.
However the ideal air standard otto cycle can be considered reversible as each of the 4 processes are reversible. I don't get what you mean when you say that the gas expands under constant volume (it just seems a funny way of describing the process), are you referring only to the increase in pressure at heat addition/rejection? As contant volume heat addition is reversible between two heat reservoirs.
I'm in the process of moving back home to all my books are packed so I can't read up to check.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
