Relationship of Critical Damping Ratio in Elastomers
The discussion focuses on estimating the critical damping ratio for RTV elastomers used as vibration dampers in a project. The user seeks specific vibrational properties, particularly damping ratios or the loss tangent (\tan\delta), from manufacturers like Honeywell and DuPont. They mention that these properties can be measured using methods such as shear rheology or dynamic mechanical analysis, but express a lack of time and resources for experimental testing. The user also requests assistance in retrieving relevant academic articles or elastomer handbooks that might contain the needed data. Overall, the conversation highlights the challenges in obtaining critical damping information for elastomers in a timely manner.
minger
Hi guys, working a project where I need to guess the damping ratio (used for a numerical analysis) based on other properties of a material. We're looking to use an RTV as a vibration damper (we don't need a lot) but I can't seem to get any vibrational properties (called Honeywell, Dupond, GESilicones, etc). Hell, if anyone has damping ratios for 'any' RTV, it would help a lot.
If anyone even has a list of any different elastomers with damping ratios, it would help a lot.
edit: Directly related is a properties called \tan\delta which I could use as well. Either work.
Find it experimentally. Bear in mind that its loss tangent will be frequency dependent and can be measured in shear rheology, dynamic mechanical analysis or other method, or just drop a ball of the material from a variety of heights and measure the rebound heights for each successive rebound. Either use a log-decrement method to find critical damping ratio, or relate a coefficient of restitution to the critical damping ratio as shown in http://link.aip.org/link/?JAMCAV/67/831/1
Let me know if you can't retrieve it (I'm assuming wherever you're working has access to it if it's an academic project) and I can LaTeX the expressions.
Edit - if that sounds like a hassle, a decent Elastomers Handbook should have some values at least.
Experimenting is kind of out of the question. We really don't have the time to obtain a sample, and then send it out for testing (we don't have the equipment or the know-how to do it here).
As far as retrieving it, I'm in the industry, but with one foot still in school. As such I have access to some journals via Ohiolink, but not the Journal of Applied Mechanics. For future reference, would you mind writing out the expressions or even emailing me the article?
I'll check our library for a elastomer book. Thanks!
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
