Change in kinetic energy Velocity not given
The discussion revolves around calculating the change in kinetic energy of a block subjected to two opposing forces on a frictionless surface. The initial and final positions of the block are provided, but the final velocity is not given, leading to confusion about how to proceed. Participants suggest using the work-energy principle, stating that the change in kinetic energy equals the work done on the block, which can be determined using the net force and displacement. Ultimately, the original poster expresses gratitude for the clarification and confirms understanding of the solution. The key takeaway is that the change in kinetic energy can be calculated using the forces and displacement, despite the absence of velocity.
rock_star
change in kinetic energy! Velocity not given :(
Two forces, of magnitudes F1 = 70.0 N and F2 = 35.0N , act in opposite directions on a block, which sits atop a frictionless surface, as shown in the figure. Initially, the center of the block is at position xi = -2.00cm . At some later time, the block has moved to the right, and its center is at a new position, Xf = 4.00 cm .
Determine the change in the kinetic energy of the block as it moves from Xi= -2.00 to X f= 4.00
Link to the diagram : http://session.masteringphysics.com/problemAsset/1011314/13/MWE_wi_5.jpg
Kinetic energy = 1/2 mv^2
Since it is starting from rest, initial velocity, V0 = 0 and then d = Vf t
But here Vf is not given..
I am not sure how to proceed when there is no velocity given
Can any more help me ?
Thanks a lot before hand
What is the net force acting on the block? Just keep the mass and velocity as variables, m and V for now. Write the equations to tell you how long it takes to get to the 2nd position, and what the final velocity is. Then see if some of the variable terms cancel out...
Change in kinetic energy = work done on the block = Force X displacement.
In the problem force and displacement is given. That is sufficient to find the KE.
Thank a lot everyone! :)
I understood it! :D
Thank a ton everyone!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
