How Do You Model a Horizontal Double Pendulum with External Forces?
  • Thread starter Thread starter nyknicks012
    Pendulum
The discussion focuses on modeling the dynamics of a horizontal double pendulum with external forces acting on each bar. The user is struggling to derive the correct differential equations and is not achieving intuitive simulation results in MATLAB. They seek assistance or resources to better understand the modeling process. Additional context about the project's purpose and a request for visual aids, such as sketches and initial calculations, are suggested to facilitate help. The conversation emphasizes the need for clarity in the setup of the equations governing the system.
nyknicks012
I'm working on determining the differential equations governing two linked bars that rotate around a fixed pivot (located at the end of one of the bars). Something like a double pendulum but rotating in the horizontal plane so gravity is not an issue. There are applied external forces at the end of each bar (2 bars = 2 forces). I tried working my way through using examples of a double pendulum I had found online, but the solution I get does not give intuitive results when simulated in matlab. Any help or link to a helpful site would be greatly appreciated.
Thanks again!
Thanks again!
Welcome to the PF. What is the context of this project? Is it an artistic project, or some mechanism for manufacturing of something, etc?
Can you post a sketch, with coordinate axes labeled, and show the forces and positions that are in your calculations? Can you post your attempt at the solutions so far, at least how you are trying to set up the DiffEqs?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
