Continuous fibre reinforced polymer
The discussion focuses on understanding how the Young's modulus of continuous fibre reinforced polymers is influenced by fibre orientation and content. It emphasizes the importance of fiber alignment, noting that modulus varies significantly when fibers are oriented parallel versus perpendicular to the load axis. A referenced source provides foundational information on these limiting cases, which can aid in visualizing the concepts. Participants are encouraged to explore diagrams that illustrate these relationships for better comprehension. This information is crucial for anyone studying the mechanical properties of composite materials.
tone999
For a continuous fibre reinforced polymer, use a diagram to explain how the Young's modulus of the composite varies with fibre orientation and fibre content.
Anywhere i could get any of this information? I've been googling with no success for a while
"www.matter.org.uk/matscicdrom/manual/co.html"[/URL] describes the limiting cases of fiber orientation perpendicular and parallel to load axis. This should be enough to get you started.
