Magnitude and Direction Word Problem
The discussion focuses on a pilot's flight path and the calculations needed to determine his return to the original destination. The pilot initially flies 45 miles west, then 20 miles at a 15° angle east of south. Participants emphasize the need to break down the journey into x and y components to apply the Pythagorean theorem for the resultant distance and use the arctangent function for direction. There is confusion regarding the correct setup of the components, particularly the y-component of the first leg of the journey. Clarifications suggest that drawing a diagram may aid in visualizing the problem and ensuring accurate calculations.
slu1986
1. The pilot of a small plane finds that the airport where he intended to land is fogged in. He flies 45 miles west to another airport to find that conditions there are too icy for him to land. He flies 20 miles at 15° east of south and is finally able to land at the third airport.
(a) How far and in what direction must he fly the next day to go directly to his original destination?
(b) How many extra miles beyond his original flight plan has he flown?
3. I know that you have to solve get the x and y components and plug them into the pythagorean theorem to get the resultant. And then do the arc tangent y/x to get the direction in degrees. I am just confused at how to set everything up. I figure that the x component of the 1st position is -45 mi since he is going west. and y - component is the sin (15) 20 mi = 5.17 mi. and plug these numbers into the pythagorean theorum = sqrt of -45^2 + 5.17^2 = 45.3 mi <---but i know this isn't right..So can someone please help me out and explain what I'm doing wrong and what I must do to do it correctly
For the second leg, 20 miles at 15o East of South the vector has both x and y components. What are they? Drawing a diagram of the whole trip should help.
Take another look at the first leg, especially the y-component. As I read the problem, the first leg is due west.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
