Is Static Equilibrium Really That Simple?
Static equilibrium involves ensuring that the sum of forces and torques equals zero. The student is attempting to solve for forces Fa and Fb using equations for static equilibrium but is uncertain about the methods used. They have derived values for Fb and Fa, which are approximately 37.21 kN and 35.74 kN, respectively. A suggestion was made to represent force components more clearly and to calculate torques about point A for simplification. The discussion emphasizes the importance of correctly applying equilibrium equations to solve static problems effectively.
urk.nono
Hello! I'm a student from Norway, and I've been struggling with a static equilibrium for a few hours now. The terms I use might not be "right", but I'll try to explain the problem to the best of my ability.
Find the forces Fa and Fb on this figure:
http://img44.imageshack.us/img44/4505/321k.jpg
\Sigma F_X = 0
\Sigma F_Y = 0
\Sigma \tau = 0 (sum torque = 0)
I solved it by drawing the forces on the figure:
http://img41.imageshack.us/img41/7513/321graph.jpg
After much fiddling with the "relevant equations" I came across the following:
20kN *3,5m - Fb * sin(30) * 5,5m = 0
=> Fb = 37,21kN
OR
20kN * 3,5m - Fb * cos(70) * 5,5m = 0
=> Fb = 37,21kN
Fa * cos(11,75) * 2m - 20m * 3,5m = 0
=> Fa = 35,74kN
I know from my measurements and by checking the solution in the book, it's pretty damn close. By which formula, or by what method I got no clue whatsoever.
I'd appreciate if someone could help me out by pointing me in the right direction :smile:
Thanks in advance
Urk
Hi urk.nono, welcome to PF. I am not sure what the second drawing you posted shows. I am used to force vectors represented as arrows, not line segments. Anyway, if you write the x and y components of the force at A as [FSUB]x[/SUB] (to the right) and Fy (up), can you find three equations saying
ΣFi,x = 0
ΣFi,y = 0
Σtorques = 0
Note: Your work will be much easier if you calculate torques about point A.
