Probability of finding electron inside bohr radius
JayKo
Consider an hydrogen atom in its ground state, what is the probability that the electron is found inside the Bohr Radius?
The probability of finding the electron at bohr radius is maximum. but the probability over the range from 0 to bohr radius, is hard to visualize.
http://www.physics.uc.edu/~sitko/CollegePhysicsIII/28-AtomicPhysics/AtomicPhysics_files/image024.jpg
graphically, the probability is area under the curve from 0 to bohr radius, but how to do it mathematically?
Hint: The area under the curve f(x) between x_0 and x_1 is
\int_{x_0}^{x_1} f(x)dx
i know this, is a calculus. but the real things is how to represent the wavefunction of hydrogen atom?
Probability=\int\psi*\psi dx
The ground state wavefunction for a hydrogen atom is computed (at least approximately) in every introductory QM text I've seen...surely you've come across it before?
alright then, will flip through it, in case i miss out. thanks. by the way, i should be working in spherical coordinate right?
ok, that would be \psi_{100}=\frac{1}{\sqrt{\pi a^{3}}e^{\frac{-r}{a}}
bingo!\psi_{100}=\frac{1}{\sqrt{\pi a^{3}}e^{\frac{-r}{a}}
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
