Finding the current in resistors
The discussion focuses on calculating the current through resistor R1 in a circuit with given resistances and a 6.00 V battery. The Loop Rule is applied to establish the relationship between the voltages and resistances, leading to the equation E - i(R1 + Req) = 0. The equivalent resistance (Req) of R2, R3, and R4 is calculated as 18.609 ohms, resulting in a total resistance of 117.6 ohms when combined with R1. The initial calculation of current resulted in an incorrect value due to a misplaced decimal point, with the correct current being approximately 0.051 A. The discussion highlights the importance of careful calculations in circuit analysis.
Oijl
In the figure, R1 = 99 . R2 = R3 = 49.5 . R4 = 75.0 , and the ideal battery has emf script e = 6.00 V.
What is i in R1?
V=IR
Junction Rule
Loop Rule?
i = E / (R+r)
The Loop Rule states that for any loop in a circuit, the sum of the voltages across the things in it will be zero. So by combining R2 R3 R4 into Req of resistance 18.609 ohms, I have a loop, so I add the voltages:
E - iR1 - iReq = 0
E = 6 as given in the problem. (Right? Maybe I'm wrong here.)
By the Junction Rule, the current i at R1 and Req would be the same.
So,
6 - i(R1 + Req) = 0
But this just gives me the equivilant resistance for all the resistors, and let's call that plain R.
So I have i = E/R, which is an equation I already had, so I felt good about coming across it via application of the two rules, but when I use this to find the current I don't get the right answer. My numerical answer to the question is 0.51016494 A.
I don't exactly know where I'm going wrong here...
Thank you for looking at this.
I get the 18.6 ohms, too. Adding R1 in series, we have 117.6 ohms.
I = V/R = 6/117.6 = .051 A. Looks like you misplaced the decimal point. Quite forgivable at this time of night.
What is the right answer?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
