Probability that Measurement of Spinor Yields Spin-Down State
gatztopher
Consider the spinor \frac{1}{\sqrt{5}}\left(\begin{array}{cc}2\\1\end{array}\right). What is the probability that a measurement of \frac{3S_{x}+4S_{y}}{5} yields the value -\frac{\hbar}{2}?
S_{x}=\frac{1}{2}\hbar\left(\begin{array}{cc}0&1\\1&0\end{array}\right)
S_{y}=\frac{1}{2}\hbar\left(\begin{array}{cc}0&-i\\i&0\end{array}\right)
I'm looking at two different ways to solve this and figuring how to choose between.
My first instinct was to be real nice, clean, and simple by expanding the spinor in the basis
\frac{1}{\sqrt{5}}\left(\begin{array}{cc}2\\1\end{array}\right)=\frac{2}{\sqrt{5}}\left(\begin{array}{cc}1\\0\end{array}\right)+\frac{1}{\sqrt{5}}\left(\begin{array}{cc}0\\1\end{array}\right)
And then going directly to squaring the value next to the down state so that P = 1/5
But that seems too easy to trust.
So I dig in my book and it says that I can expand a state in the eigenstates of the operator S_xcos(phi)+S_ysin(phi) (which are complex) which would end up looking like
\frac{1}{\sqrt{5}}\left(\begin{array}{cc}2\\1\end{array}\right)=\alpha_{+}\frac{1}{\sqrt{2}}\left(\begin{array}{cc}e^{-i\phi/2}\\e^{i\phi/2}\end{array}\right)+\alpha_{-}\frac{1}{\sqrt{2}}\left(\begin{array}{cc}e^{-i\phi/2}\\-e^{i\phi/2}\end{array}\right)
I solve for alpha-minus in an <alpha|S sort of way...
\alpha_{-}=\frac{1}{\sqrt{10}}\left(\begin{array}{cc}e^{i\phi/2}&amp;-e^{-i\phi/2}\end{array}\right)\left(\begin{array}{cc}2\\1\end{array}\right) \Rightarrow \frac{1}{\sqrt{10}}(cos(\phi/2)+3isin(\phi/2))
And square it to get probability so that
|\alpha_{-}|^2 = \frac{1}{10}(cos^2(\phi/2)+9sin^2(\phi/2))
Where phi happens to be the arctan(4/3) (because when you look at how the operator is put together it has the complex number 3-4i bouncing around which corresponds to a 3-4-5 Pythagorean triple where phi would be the angle between x=3 and r=sqrt(x^2+y^2)=5) and this results in P = .259
Two different paths to two different solutions, the first just too simple and the second pretty complex... I'd like to know, which, if either, is right, and also why.
Thank You So Much!
The first method is incorrect. You expanded in the z basis. But your operators are Sx and Sy. So the basis vectors in the z basis are not eigenvectors of the operator you're looking at.
Your second method looks more or less correct. I'm not going to check the algebra, though.
Another way to tackle this is to look at the expectation value
\langle \chi | \left( \frac35 S_x + \frac45 S_y \right) | \chi \rangle
which can be evaluated by simple matrix multiplication. Since there are only two possible spin states (+\hbar/2 and -\hbar/2), the expectation value will tell you exactly how their probabilities must be weighted. For example, if the expectation value is 0, then the spin states must be weighted equally, etc.
Note, however, that this trick only works for spin 1/2. For spin 1 and higher, in general, there are more than two possible spin states, so merely calculating the expectation value of the spin is not enough information to determine all the weights. In general, you must expand the state spinor in eigenvectors of the spin operator to find the probabilities for each value of spin angular momentum.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
