Calculating F2 for Double and Triple Changes in Coulombs Law"
The discussion focuses on calculating the electrostatic force (F2) when both the distance between two charges is doubled and the size of the charges changes simultaneously. The original example provides a force of 6.0 x 10^-8 N, with the first change resulting in F2 being 1.5 x 10^-8 N when the distance is doubled. When considering the changes in charge sizes, the new force is calculated to be 3.6 x 10^-7 N after applying the factors of 2 and 3 to the charges. Participants clarify the correct values for the charges and distance, confirming that the new distance is 2r and the charges become 3q1 and 2q2. The final rearrangement leads to the conclusion that F2 equals 6F1/4.
wilson_chem90
Look back at the Example in the Using Coulombs Law-Comparative Analysis section. Calculate the magnitude of F2 if both changes occurred simultaneously-that is, if the distance between the charges doubled and the size of once tripled, while the size of the other doubled.
This is the original example:
If the electrostatic force between two charges is 6.0 x 10^-8 N, what effect would each of the following changes have on the magnitude of the force?
1) the distance between the charges is doubled
2)One charge is doubled and the other is tripled
Solution:
1)
F2 = (6.0x10^-8 N)xr1 / (2r1)^2
= (6.0x10^-8 N) / 4
= 1.5 x 10^-8 N
2) q1=2q1
q2=3q1
F1/F2 = q1q2/q1q2
(6.0x10^-8 N)/F2 = q1q2 / (2q1)(3q2)
F2 = (6.0x10^-8N)(6)
= 3.6 x 10^-7 N
This is the solution to the example!
I can do the actually solution to this problem, but my only question is what are the values of q1 and q2 and r? Since they're literally exactly the same in both questions, does it mean that they all just double and triple from the original? Meaning r = 4r1, q1 = 6q1, q2 = 6q2
Does anyone have any suggestions?
Thank You
I don't understand where you get the factors of 4 and 6 from.
Double = multiply by a factor of 2.
Triple = multiply by a factor of 3.
The only difference is that, instead of making each of these changes separately, ALL three changes are now to be made at the same time so that (primed symbols represent the "new" quantities after the changes):
r' = 2r
q1' = 3q1
q2' = 2q2
ohh okay, sorry i thought it mean't something else.
Do i ended up setting F1/F2 = (q1q2/r1^2) / ((3q1)(2q1)/2r1^2)
I rearranged it to be F2 = 6F1/4r1 (after cancellations and rearranging)
Im not sure if i rearranged it correctly...
sorry i forgot to cancel r1, its actually F2 = 6F1/4
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
