Infinite Square Well with uniform probability density for a/4<x<3a/4
zoso335
The potential for an infinite square well is given by V=0 for 0<x<a and infinite elsewhere. Suppose a particle initially(t=0) has uniform probability density in the region a/4<x<3a/4 :
a.) Sketch the probability density
b.) Write an expression for the wavefunction as t=0
c.) Find the normalization constant
d.) What is the probability of finding the particle in the lowest eigenstate of the well?
e.) What is the probability of finding the particle in the second lowest eigenstate of the well?
I have no idea what to do this for this since the wave function is always described as wavelengths in the well, but since its uniform for a/4<x<3a/4 I don't know how to set it up right
Hi zoso335, welcome to PF!:smile:
What do you mean by "the wavefunction is always described by wavelengths in the well"?
well the probability density is the magnitude square of the wave function. And, the wave function of an infinite well always fits an integer multiple of half wavelengths. So, since the probability density is uniform, the wave function has to be uniform in this region, but I don't know how to find the wave function outside this region but still within the well.
No, the eigenfunctions always fit an integer multiple of half-wavelengths...What are these eigenfunctions? Is it possible for the wavefunction of this particle to be in one of these eigenfunctions? Does it have to be?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
