Unitary Matrix, need to find eigen values/vectors
orbitsnerd
matrix:
1/sqrt(2) i/sqrt(2) 0
-1/sqrt(2) i/sqrt(2) 0
0 0 1
Find eigen values and eigen vectors and determine if it is diagonalizable
The matrix is unitary because Abar*Atranspose=I (identity matrix)
I am having problems solving for the eigenvalues and vectors because of the imaginary numbers. What I get is:
lambda-1/sqrt(2) i/sqrt(2) 0
-1/sqrt(2) lambda- i/sqrt(2) 0
0 0 lambda-1
=(lambda-1/sqrt(2))*(lambda- i/sqrt(2))*(lambda-1)-(i/sqrt(2))*(-1/sqrt(2))*(lambda-1)
I need help getting to the next step.
Thanks!
Hi orbitsnerd! :smile:
0 0 lambda-1
(euuugh! have a lambda: λ and a square-root: √ :wink:)
Look at it … (λ - 1) is obviously a factor of the determinant, so you can ignore everything except the four top-left entries:
Code:
λ - 1/√2  i/√2
 -1/√2    λ - i/√2
so what is the determinant of that? :smile:
Awesome short cut. I now have my eigenvalues as:
λ1=1, λ2=(1+√3)/(2√2) + [(1-√3)/(2√2)]i and λ3=(1-√3)/(2√2) + [(1+√3)/(2√2)]i
I have issues finding the eigenvectors. I know you need to plug in the values of each λ back into the original matrix and solve for e1, e2 and e3. The imaginary number throws me off in this case.
Code:
λ - 1/√2  i/√2
 -1/√2    λ - i/√2
I don't see what the problem is :confused:
just do it the usual way. :smile:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
