Mass being dropped on spinning disk problem NEED HELP
A disk with a radius of 1.25m and a mass of 10kg is spinning at 10 rad/s when a 5kg mass is dropped onto it at a distance of 0.50m from the center. The problem involves calculating the time and distance the mass slips on the disk, given a coefficient of kinetic friction of 0.40. Participants are encouraged to share their attempts and specific points of confusion to facilitate assistance. The discussion emphasizes the importance of showing work to receive effective help. Engaging with the community can lead to a clearer understanding of the physics involved.
jch11
Mass being dropped on spinning disk problem NEED HELP!
1. A disk has a radius of 1.25m and a mass of 10kg. It lies flat on a smooth table and is spinning with an initial velocity of 10 rad/s about a pin at its center. A 5kg mass is dropped on it at a distance of 0.50m from its center. Find:
(Extra credit) if the coefficient of kinetic friction between the block and the disk is 0.40, determine:
i. the time while slipping
ii. the distance traveled while slipping
Welcome to PF!
Hi jch11! Welcome to PF! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
