Designing a 550 V, 3A DC power supply using a multiplier circuit
A user seeks to design a 550 V, 3A DC power supply using a Villard Cascade multiplier circuit instead of an expensive variac and bridge rectifier. They found a resource detailing the use of capacitors and diodes to achieve a pseudo DC effect but need guidance on determining the appropriate capacitor sizes and quantities. The design considerations include the input frequency, acceptable ripple, and the number of stages in the multiplier. It is also recommended to use bleeder resistors across each capacitor for safety due to the high voltages involved. The discussion emphasizes the importance of understanding the relationship between capacitance values and circuit performance.
trini
Ok so i received the suggestion to get such a power supply by rigging a variac to a bridge rectifier, but variacs are rather expensive, so after some snooping around i came around this site:
http://www.scribd.com/doc/9779212/ebook-free-energy-50000-vdc-power-supply
they basically just use a combination of capacitors and diodes to get a pseudo DC effect, and it is mentioned that by altering the values of capacitance, i can get the DC pulse trains i require, however they don't mention an exact relationship between the two. What i would like to know is if i use such a circuit, what formulae may i use to determine the size and amount of capacitors to use?
That circuit is called a Villard Cascade, the size of capacitors you decide to use depends on the frequency of the input and what is an acceptable amount of ripple, as well as how many stages your multiplier uses. It is also good practice to place bleeder resistors across each capacitor in the circuit as these voltages are potentially lethal. Here is a link to all the formulas you could want for capacitance.
http://en.wikipedia.org/wiki/Capacitance
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
