Accelerating blocks connected by a spring
The problem involves two blocks connected by a spring on a frictionless surface, where a force is applied to one block. The scenario includes determining the magnitude of the applied force during a specific time interval while considering the dynamics of the system, including spring compression and kinetic energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the relationship between the final velocities of the blocks and the applied force, exploring conservation of momentum and energy principles. Some question whether considering the center of mass could simplify the problem. Others express confusion regarding the equations and the number of unknowns involved.
The discussion is ongoing, with participants offering various approaches and equations. Some guidance is provided regarding the use of conservation laws, but there is no explicit consensus on the best method to resolve the problem. Multiple interpretations of the forces and motions are being explored.
Participants note the challenge of having multiple unknowns and the implications of the spring's behavior on the overall dynamics. There is mention of needing to clarify the role of the distance in relation to the center of mass.
XanziBar
Two 3.0 kg blocks on a level frictionless surface are connected by a spring with spring constant 1000 N/m. The left block is pushed by a horizonal force F to the right. At time t=0 seconds, both blocks are moving with velocity 3.2 m/s to the right. For the next second, the spring's compression is a constant 1.5 cm. What is the magnitude of F during that 1.0 s interval
KE=.5*m*v^2
SPE=.5*k*(delta x)^2
F=(delta p)*(delta t)
change in energy = force * distance
I tried to setup the following: Ei= .5*6kg*3.2^2
and Ef=Ei+F*d=.5*m*v1^2+.5*m*v2^2 +.5*k * (delta x)^2
Now I know everything about the spring potential energy at the end and the total energy (kinetic) at the beginning. But I guess the biggest problem I'm having is that I do not know the final velocities of either of the 2 blocks. I tried using conservation of momentum to relate them but got a much bigger mess with no obvious way to simplify. Would considering the center of mass of the 2 block system help? If I have the acceleration of the center of mass can I do something with that? Is this even the right approach at all? No matter what I do I get like 1 equation with 3 unknowns! Please help.
So... the change in momentum, F*(delta t)=m*v1f+m*v2f-2*m*v then that's a relationship between v1f and v2f in terms of the force (which is what I'm looking for). But with (1/2)*m*v1f^2+1/2*m*v2f^2+1/2*k*(delta x)^2=m*v^2+F*d that still leaves me with an unknown and no equation. Also, does the distance represent the distance that the center of mass travels?
Kind of struggling here, any ideas anyone?
F=-kx ?
No, the force on the spring is not the same as on the block. X1=Vo+a1/2 X2=Vo+a2/2.
a1-a2=2*1.5 cm
F-kx=ma1
kx-ma2
F=m*(a1+a2)=3*(10.03)
==>> a2=5 m/s^2
a1=5.03 m/2^2.
Anyway, the forces are not the same but this problem should be do-able with conservation of energy/momentum.
I just drew an fbd and solved and got 30n.
  • · Replies 33 ·
  • · Replies 17 ·
