Vector Quantities: Can Unit of Measurement Reveal Vector?
  • Thread starter Thread starter Char. Limit
    quantities Vector
The discussion centers on whether the unit of measurement can indicate if a quantity is a vector or a scalar. It is established that units alone do not determine the nature of a quantity; both vectors and scalars can share the same units. For instance, displacement is a vector measured in meters, while distance is a scalar also measured in meters. The conversation highlights that while some units may not commonly associate with vector quantities, it is theoretically possible to create a vector with any unit. Ultimately, the distinction lies in the definition and context of the quantity rather than its unit of measurement.
Char. Limit
Can someone tell, using the unit of a physical measurement, if the measurement is a vector? For example, without knowing about force, can one tell by the unit kg-m/s^2 that force is a vector?
I'm trying to say, for example, thay since the m in kg-m/s^2 is a vector (for example), the whole thing is a vector... I probably sound dumb...
Does the unit or system have a magnitude of some sort? Does it have a direction of some sort? If it meets both conditions, it's a vector.
Well... let's say I invented a new, unused unit... I'll say m^2/s. Could you tell, just by that unit, if the quantity is a vector?
No. The units have nothing to do with whether the quantity is a vector or scalar. I could perhaps invent a vector quantity with the units m^2/s and a scalar quantity with the same units. Or even several of each.
Example: take the unit of length, the meter. There is a vector quantity, displacement, and a scalar quantity, distance, that are both measured in meters.
Example 2: Current, measured in amperes, can be a scalar or vector depending on who you ask.
Caveat: for some units, there don't happen to be any meaningful vector quantities associated with them. For example, off the top of my head I can't think of a vector quantity with units of mass. Or time. But there's no mathematical reason that one couldn't be created.
Thanks.
I am confusing myself a little. When you say "the velocity is 5 m/s north", you really are saying "the magnitude of the velocity vector is 5 m/s, and the direction is north"- so the actual unit is attributed to the magnitude, a scalar. The vector itself doesn't have a unit, but is composed of a set of scalar components, each with their units. From this perspective, only scalars can have units. I could feasibly construct a vector [x,y] in which x and y are scalars with different units, for example in polar coordinates x is a distance and y is dimensionless (the polar angle, in radians, so a ratio of two distances), then there is no convention I know of how to give this vector a unit.
For me it is meaningless to say the vector has units... the vector gives you the location of a point in whatever space you are talking about, and a point does not have units. The distance in that space to a set of normal planes can have units, however, so each component can have units.
Any disagreement with this view?
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
10K
17K
