Change in Velocity Homework Solution
To find the change in velocity of water in the pipe, the entry and exit velocities must be expressed as vectors in xy coordinates. The change in velocity is calculated using the equation V1 - V2, where V1 is the entry velocity and V2 is the exit velocity. The subtraction of these vectors will yield the resultant change in velocity. It is essential to draw the resultant vector to visualize the change. This approach will provide a clear understanding of the velocity change in the system.
lil08
Water enters and leaves a pipe as shown at a steady speed of 1.5. Find the change in velocity.
http://kv8v6q.blu.livefilestore.com/y1pjsZ-s4z6_sTZEgW2-nsZ8pf1YrZml2cqcsXxgwnDNbUzFlaPXJcSe_nX93qAi6xd_Z7BATO9oBNXPDbxrGoJHEkk6WbzV3wR/0.bmp
V1-V2=Change in Velocity
I need to draw the resultant. What next?
Welcome to the PF. I believe that they want you to calculate the change in vector velocity. So express the entry velocity as a vector in xy coordinates, and the exit velocity in xy coordinates. The difference is just the subtraction of the two vectors, carried out with components.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
