How to Determine Time Ordering in Phi-3 Theory for a 2-to-3 Particle Process?
tayyaba aftab
i have been given a problem for writing s matrix in second order perturbative theory for an interaction hamiltonian with phi 4 and phi 3 contributions.
it is also given that our initial state is of 2 particles and final state is of three particles.
now in solving that i have to take time ordering of the hamiltonian at two different points.
problem is that i am unable to guess the right term of time ordering for the cpndition of two in coming and three outgoing particles.
can some body please help me in writing that.
i have to submit my assignment after vacations
so its urgent:frown:
tayyaba
You don't have to guess here.
I will just cover the phi cubed case.
Are you allowed to use Feynman's rules?
If yes, just draw the 2+3 external lines and two vertices with three outgoing lines each and draw all topologically distinct diagrams. After that, you can write down the terms very easily.
If not, use Wick's theorem to transform the time-ordered into a normal-ordered product:
T\left[\phi^3(x)\phi^3(y)\right]=N\left[\phi^3(x)\phi^3(y)+\mathrm{all\, possible\, contractions}\right]=N\left[\phi^3(x)\phi^3(y)\right]+9D_F(x-y)N\left[\phi^2(x)\phi^2(y)\right]+18D_F^2(x-y)N\left[\phi(x)\phi(y)\right]+6D_F^3(x-y)
where D_F denotes the Feynman propagator. Please check the combinatorial factors. After that, write out the normal-ordered products to see which terms remain after contracting them with the creation and annihilation operators.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
