Vector Addition: Finding Resultant and Direction - Easy Homework Solution
The discussion focuses on calculating the resultant of three vectors and their direction. The user calculated the X and Y components of the vectors, resulting in a magnitude of 3.64 for the resultant. However, clarification is needed regarding terminology, as the magnitude is not the resultant vector itself. The direction calculation using arctangent is also critiqued, as it only provides angles between -90 and +90 degrees, necessitating additional context about the quadrant. Overall, the calculations are mostly correct, but precision in terminology and directional context is essential.
seizureboi
I have three vectors and I need to find the resultant of the three vectors and direction.
*All angles are with the horizontal
Vector 1 = 18 at an angle of 40 degrees (First Quadrant)
Vector 2 = 10 at an angle of 72 degrees (Second Quandrant)
Vector 3 = 22 at an angle of 55 degrees (Third Quadrant)
In the X I got: 18cos(40) - 10cos(72) - 22cos(55) = -1.9
In the Y I got: 18sin(40) + 10 sin(72) - 22sin(55) = 3.1
√(-1.92 + 3.12) = 3.64 is the resultant
tan-1(3.1/-1.9) = -58.5 degrees is the direction/angle
I just need confirmation whether this is right or wrong. =)
Looks good. Well, almost perfect. You should be a little careful with your terminology.
The resultant is a vector, the sum of the three vectors, and it has a magnitude and direction. The 3.64 you found is the magnitude of the resultant, not the resultant itself.
For the direction, you need to be a little careful because arctangent only returns angles between -90 degrees and +90 degrees. You should give a little more information to indicate exactly what the angle is, e.g. which quadrant, measured relative to what, etc.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
