Calculate Total Upward Force Skateboard Mass 65kg, Half Pipe 3m
  • Thread starter Thread starter Masafi
    Force
To calculate the total upward force on a skateboarder with a mass of 65 kg at the bottom of a 3m half pipe traveling at 3.6 m/s, the upward force, or normal force (N), can be determined using Newton's second law. The total upward force includes both the centripetal force and the gravitational force acting on the skater. The formula can be expressed as N = mac + mg, where 'a' is the centripetal acceleration. The discussion clarifies that the term 'total upward force' refers to the normal force exerted by the surface. Understanding these forces is essential for accurately calculating the dynamics involved in skateboarding on a half pipe.
Masafi
skateboard mass = 65kg
he skates down on a half pipe, radius = 3m
If he is traveling at 3.6 m/s when at bottom of ht hallf pipe, what will be the total upward force?
Is this basically the centripetal force + the reaction to the weight?
i.e. centripetal force + mg?
The phrase 'total upward force' is a bit ambiguous, as is the term 'reaction to the weight'. Presumably you want the upward force that the surface exerts on the skater (usually called the 'normal force', N).
If so, you have the right answer. But a simpler way to understand it is to apply Newton's 2nd law:
ΣF = ma
N - mg = mac
Thus: N = mac + mg
