Connect Laser Pointer to PC Wirelessly: Step-by-Step Guide
A project is underway to create a wireless laser pointer that connects to a PC, allowing users to shine it on a screen and leave traces visible until the slide changes. The setup involves a modified laser pointer with a Bluetooth transmitter that activates the PC's webcam to record and project the laser's traces. The main challenge is establishing a wireless connection between the laser pointer and the PC, as the creator lacks programming skills. Suggestions include exploring Wireless USB options from Cypress Semiconductor as a potentially simpler alternative to Bluetooth. The discussion highlights the need for accessible hardware and software solutions to facilitate this project.
ragefire
Hi all, i am doing a project to make a laser pointer that can connect to the PC wirelessly. Here's how it works.
-using the modified laser pointer, shine it on the screen from anywhere in the room and the dots/lines will remain on the screen until the user changes slide.
Background: once the laser pointer is switched on, the webcam from the PC will begin recording all the traces of the laser shone on the screen. All these detected traces will then be projected back on the screen.
Question: I already have the laser pointer done up but the problem i am facing now is how do I link it up with the PC wirelessly. As mentioned, the laser pointer will be equipped with a bluetooth transmitter which will send a signal to the PC's webcam once the laser pointer is activated. As I am not good in programming or software writing and stuff, i was wondering if anyone could provide help on how I can solve this laser pointer to PC communication problem as I have not a single idea on how i can link them up at the moment. Thanks.
*I really do hope there are programmable bluetooth adapters in the market which also provides step by step software compilers to aid in my task*
Instead of bluetooth, maybe check out the Wireless USB resources from Cypress Semiconductor. That may be an easier way to go.
hey, thanks alot. I've visited the site and found many useful hardwares which i can consider as an alternative. thanks once again =)
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
