Rotating Cylinder, Centripital Motion, and Coeffients of friction.
Imatree
So, in a popular amusement park ride, a cylinder with a radius of 3.00 meters is set in rotation. The floor then drops away, and leaves riders suspended against the wall in a vertical position.
a. If the Cylinder rotates at 50 RPM, what minimum coefficient of friction between a rider's clothing and the wall of the cylinder is necessary to keep the rider from slipping?
b. If the coefficient of friction between the rider's clothing and the wall of the cylinder is 0.200, at what minimum rotational speed (in RPM) must the ride rotate?
a = V2 / r
Ff= μFn
V = 2πrRPM / 60
F = ma
So, I started with Drawing a diagram of this situation. I drew a cylinder with a radius of 3m, and spinning at 50RPM. The forces I drew were Fa, so the centripetal force, and the force of gravity on the rider. Then I used the V = 2πrRPM / 60 to get my velocity of 15.71 m/s, plugged that into the a = V2 / r to get an acceleration of 82.246 m/s2, then plugged that into the F = ma equation. I assumed a mass of 10kg for the rider (no mass was given), and got an inward force of 822.467N. Now I'm completely stuck. I have the Ff= μFn equation, but I do not have a force of Friction, and I need to solve for Mu. I'm also not sure if I need to use the inward force for this equation, instead of the force of gravity.
Don't do this. It will work out in the end, but it's better to leave "m" in the equations and see if it cancels out at the end (as you would expect).
Fn is the normal force. Have you drawn a free body diagram, or can you visualize all the forces on the rider? When you add up the frictional force, the weight force, and the normal force, what do you get?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
