Beat FrequencyWhat is the new tension in the string that slipped?
  • Thread starter Thread starter r_swayze
    String Tension
Two identical strings initially under 228 N tension produce a fundamental frequency of 156 Hz. When one string's tension decreases, a beat frequency of three beats per second is observed, indicating a new frequency of 153 Hz for the slipped string. The relationship between frequency and tension for identical strings is expressed as f1/f2 = (T1/T2)^(1/2). Given T1 and the frequencies, the new tension T2 can be calculated. The discussion highlights the need for additional variables like linear density or wave speed to find the tension accurately.
r_swayze
Two identical strings are sounding the same fundamental tone of frequency 156 Hz. Each string is under 228 N of tension. The peg holding one string suddenly slips, reducing its tension slightly, and the two tones now create a beat frequency of three beats per second. What is the new tension in the string that slipped?
My attempt so far:
fbeat = f1 - f2 = 3Hz
f1 = 156Hz
3Hz - 156Hz = -f2
f2 = 153Hz
So how do I find the tension for this frequency? Usually there is more information given such as the linear density or speed of the wave. I don't see how I can find the tension without those variables. Any help?
For identical strings frequency f = k*(T)^1.2, where k is constant and T is the tension in the string. So
f1/f2 = (T1/T2)^1/2.
You have already found f1 and f2. T1 is given. Find T2.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
