How Does Non-Linear Friction Affect Torque in Drilling?
Non-linear friction's impact on torque in drilling is explored through the relationship between frictional torque and normal force. The discussion highlights the need for a formula to determine the torque required to overcome friction when a shaft or drill tip contacts a surface. The equation τ_friction = β F_normal is proposed, but its validity and derivation are questioned, particularly for different shapes. The conversation reveals that frictional torque is not widely covered in literature and depends on the dimensions of the contact area. The participants seek further guidance on deriving expressions for various shapes to better understand this phenomenon.
Sumtwit
Hi everyone.
This is not a homework problem. I am very familiar with the case of linear(direction) friction.
F_{friction}=\mu F_{normal} ...(1)
However my question is closer to something like this:
\tau_{friction}=\beta F_{normal} ...(2)
Where \tau_{friction} is a torque
Imagine if a shaft were to be making contact with the floor at its stub. Assuming the normal force that the shaft exerts on the ground is known. Then how much torque would need to be applied around the shafts axis to make it overcome friction and start turning.
Maybe another analogy would be a drill with a flat tip, how much torque would the flat tip need to overcome friction ?
Is equation 2 of the right form ? what name does this effect go by because so far I could only find references to linear friction.
Frictional torque on flat tip of round solid rod, T = mu*(d/3)*N, where d = rod diameter, and N = normal force rod exerts on floor. This assumes the rod is normal to the floor surface.
Hi nvn, thanks that helps a lot. I see "frictional torque" doesn't appear to be a very well covered topic. I was surprised to see that it is a function of the dimensions of the contacting area.
Could you please guide me to a derivation of frictional torque ? I would like to find an expression for other shapes as well.
Pressure[/color] p = N/A; rod diameter D = 2*r2.
\begin{equation*}\begin{split}T<br /> &amp;= \int\int r{\cdot}(\mu\,p)\,dA\\[0.5mm]<br /> &amp;=\ \mu\,p\int\int r\,dr\,(r\,d\theta)\\[2mm]<br /> &amp;=\ \mu\,p\int_{0}^{2\,\pi}\int_{0}^{r_2}r^2\,dr\:d\theta\\[3mm]<br /> &amp;=\ (D/3)\,\mu\,N\end{split}\end{equation*}
OK Thanks! that helps a lot :)
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
