How do you integrate integrate ψ1(x)?
  • Thread starter Thread starter maxbye3
    Integrate
maxbye3
Normalise Ψ(x,0) (use the fact that both ψ1 and ψ2 are stationary states).
Will this wave function be normalised at any later time, t > 0?
A particle in an infinite square well of width a has as its initial wave function an even mixture of the first two stationary states,
Ψ(x, 0) = A(ψ1(x) + ψ2(x)) .
I get the concept of normalisation I would integrate the square of A(ψ1(x) + ψ2(x)) between 0 and a and equate it to 1.
I am confused how to integrate ψ1(x) or ψ2(x) i.e. is it as simple as (ψ1(x)*x)/2?
Perhaps I can say ψ1(x) = the time-independent Schr ̈odinger equation for the infinite square well un=(2/L)^0.5sin(nx/L)
Anyway any help would be deeply appreciated, thanks.
I hope i will be helpful (but don't completely count on what I am going to say)..
well, the whole idea of normalization is to determine that "A" ,and that can be accomplished through taking the integral of square (A(ψ1(x) + ψ2(x)) between 0 and a and equate it to 1) as you stated .. I don't think you would need to break them , you can do the integration as the following:
integral(from 0 to a) [of] : square(A(ψ1(x) + ψ2(x)) dx
// ;square(A(ψ1(x) + ψ2(x)) = A^2(ψ1(x))^2 + A^2(ψ2(x))^2 + 2A^2 ψ1(x)ψ2(x)
taking the integral(from 0 to a) [of] A^2(ψ1(x))^2 dx = A^2 integral((ψ1(x))^2 dx , since the integral of ((ψ1(x))^2 dx =1 , then the first term is A^2
doing the same thing with the second term you will also get A^2
the third term as can be seen is an integral of both integral ψ1(x)ψ2(x) , this one will give zero (why?) you can verify this by making use of orthognality ..
so finally you will end up with : A^2 +A^2 =1 >> 2A^2=1 >> A^2=1/2 >> A=sqrt(1/2)..
then the normalised function : sqrt(1/2)*(ψ1(x) + ψ2(x))
hopefully , this answers the part of the question which asks to normalize Ψ(x,0) .. :)
How did you come up with that? What do you get when you square \psi?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
